Rough Idle and Take Off?
Old Jun 5, 2010 | 07:46 PM
BrettAdams's Avatar
Ok all of a sudden one morning my '06 4.6 Started to run terrible.. so today I changed my plugs to NGK and Gaped them with Dielectric Grease and all went ok on chaning them out.. Still tho it runs like crap... rough idle and take off skips and sputters then gains alittle back as you go. The dealership told my #5 Coil was out but my Edge told me #4.. so I changed #5 with a new one and also when I was changing out my Plugs I noticed that #2 and 3 Plugs were loose and the threads on #3 were ruined some along with the Coil being burnt.. So what do you guys think it could be. The Edge is now saying the Crank Position Sensor Code and the Test Not Complete Code.. I cleared them and its not showing the Crank one anymore.
Old Jun 6, 2010 | 04:00 PM
BrettAdams's Avatar
Anyone just replaced #2,4,5 Coils to new and still running like ****.
Old Jun 7, 2010 | 03:28 PM
BrettAdams's Avatar
Could it be the MAF Sensor needs to be cleaned. Its got new Plugs and the Coils are fine.
Old Jun 7, 2010 | 05:11 PM
BrettAdams's Avatar
Cleaned the MAF Sensor and still does it... Starting to think its a Vaccum Line that is broke or cracked... Anyone have anything?
Old Jun 7, 2010 | 05:30 PM
mdhawkin's Avatar
If I remember correctly there were some people with this similar issue, I believe some of them cleaned the throttle body itself. Also have you checked the fuel filter?
Here is a link to a thread concerning cleaning the TB: https://www.f150online.com/forums/ar...ttle-body.html
I honestly think cleaning the MAF is more important but you have already done that.....I will keep thinking about this one.
Old Jun 7, 2010 | 06:10 PM
BrettAdams's Avatar
Ok I went back up there and with the Truck running we unplugged #2 Coil and it did not make a diff on the truck rough idle.. We unplug #1 and it made a big difference. We then tested the Coil with is one day old anyways and its good with it hooked up and running. So could it be internal?
Old Jun 7, 2010 | 06:56 PM
jgger's Avatar
Check the connectors where the coils plug in.
Old Jun 7, 2010 | 08:38 PM
mdhawkin's Avatar
You lost me a little with this post. Are you saying you tested the number 2 coil and it was good? Also did you unplug number 1 while number 2 was also unplugged? If you unplugged each one individually it sounds like you still have an issue with number 2 (as in it was already not firing) when you unplugged number 1, you went from 7 to 6 cylinders. You can swap it with a known good coil (reverse 1 and 2) and unplugging 2 still does not make a difference you probably have a problem with the wiring going to number two itself or maybe the injector on number 2.
If you could clarify a little more I will try to help trouble shoot.
Old Jun 7, 2010 | 08:45 PM
BrettAdams's Avatar
Ok #2 Coil pack is brand new.. I took #2 off seperatly from #1. I disconnected #1 and could tell a diff in ideling.. Then I unhooked #2 and no diff in ideling. The Shop put a tester on the coil while it was running and it checked out good and working just like #1 did along with the others. So the wiring should be good and the Coil is good, and the Plug is brand new (installed Sat). Also when I went to remove my old plugs.. #2 was already loose and the threads were ruined and so was the coil.. thats why I got a new one. So do you think it could be a clogged fuel injector?
Old Jun 7, 2010 | 08:58 PM
mdhawkin's Avatar
Well back to the old rule of fuel and fire, sounds like you have fire covered which makes me think fuel could be an issue. I don't know if the plug being loose could have caused any major internal issues. I don't know what they used to test the coil pack but I am guessing its an inline tool between the wiring and the coil itself? Back in your original post you said it happened almost instantly, I would not be surprised if the injector is your issue.
Old Jun 7, 2010 | 09:35 PM
BrettAdams's Avatar
Yes it did just happen over night.. Can a Injector just go bad or could be clogged.. Can they be unclogged or are they just bad. He used the thing that looked like a Horse Swater thing and when he put it on the Coils the light on top would tick with the current.
Old Jun 8, 2010 | 01:36 AM
I think it's time for a compression test and possibly a borescope.
Old Jun 8, 2010 | 01:49 AM
thorherc67's Avatar
i have the exact same issue!
Last week i took my truck in and replaced coil 5 which was out and 3 and 4 as well.
And my truck has the same problems you have. let me know what the deal is on yours because i prob have the same
Old Jun 8, 2010 | 08:56 AM
BrettAdams's Avatar
Ok well this morning coming from work I noticed that its better for some reason.. which leads me to think its the injector because of how fast the problem starter and now how its slowly starting to get better. Maybe I got some bad gas some where, or something in my line.. Still no where close to be 100% but better.. Guess Ill just keep driving it around and add another bottle of Fuel Injector Cleaner.
Old Jun 8, 2010 | 09:24 AM
mdhawkin's Avatar
Good luck, keep us posted. Curious to what you find out.
