06 Ford F150 Grinding/Rattling Noise Please Help
Old Jun 2, 2010 | 04:12 PM
Mclovin05's Avatar
Question 06 Ford F150 Grinding/Rattling Noise Please Help
Hello everyone first time on the forums. I have an 06 F150 regular cab,V6 ,automatic. I recently changed the brakes on it. Soon after, I started driving the truck I noticed a grinding noise sounds like metal on metal almost. This happens right after I put it into gear and start idling forward, and also when I come to a stop. It does not happen while driving normal speeds only when idling or at a stop. I thought it was the brakes at first but when the noise continued after I came to a stop that ruled out that problem, and now I'm at a loss. I was hoping somebody could point me in the right direction before I drive over to Ford for a diagnostic. Somebody mentioned it could be the IWE Solenoid, what is the IWE Solenoid? and how could it cause these problems? Thanks
Old Jun 2, 2010 | 04:20 PM
City of Champs's Avatar
It's not an iwe solnoid meaning an indipendent wheel end. It's a spring enguaged vaccum disconnect means of enguaging or disenguaging 4x4. You would only hear that noise like ice in a blender while in motion and it would completly stop if you were to enguage 4x4.
Now if you just did your brakes I'd take the wheels off and have a look before I paid ford money to feel dumb bc you made a small mistake. make sure nothing is rubbing and look for scratch marks on the rotors and wheels as a tell tail sign
also. Guy could check things that are in motion when your truck isn't. Say the fan or belts. Maybe it's a tensioner or idler bearing
Old Jun 5, 2010 | 09:56 AM
60DRB's Avatar
If you hear the noise while stopped, it's NOT the IWEs or the brakes. My first guess would be one of the serpentine belt pullies having a bad bearing.
