need a quick answer
Old May 28, 2010 | 12:19 PM
snopro31's Avatar
need a quick answer
How deep can a stock 06 F150 4x4 with 18's go before it starts to suck water or die?
Old May 28, 2010 | 12:30 PM
mdhawkin's Avatar
Should be good as long as your airbox does not go under. With that said you may have water in your cab before you have issues. Now if you go speeding into a hole and basically create a wave that you drive through, you could suck up water unexpectedly.
If you dont mind can you shed some light on why you are asking this question?
Old May 28, 2010 | 12:35 PM
snopro31's Avatar
10cm of rain coming, ditches are saturated already, rivers are high. Not offroading but trying to get around on the roads if all the rain does actually come.
Old May 28, 2010 | 12:39 PM
mdhawkin's Avatar
Got ya, on a good road bed, take your time and be safe and you should be good. In my old truck I have been deep enough to get water inside the cab and never had a problem with sucking up water.
Old May 28, 2010 | 12:40 PM
snopro31's Avatar
Im hoping its going to turn to snow as the temps are dropping but it will probably just rain.
Old May 28, 2010 | 12:58 PM
kingfish51's Avatar
You will have to worry about water being sucked into the diffs, TC, and trannie before it will be sucked into the engine.
Old May 28, 2010 | 12:59 PM
305f150's Avatar
It's amazing your talking about snow, it is easily 90 deg here in miami right now. Dont you have summers at all???
Old May 28, 2010 | 01:03 PM
maplesyrup's Avatar
No we dont :P:santa:
Old May 28, 2010 | 01:05 PM
snopro31's Avatar
we have 3-4 months of summer then pre winter and post winter.
actually i wouldnt be surprised if it snows at the cabin.
that would be a lot of snow.
Old May 28, 2010 | 01:08 PM
xr8d302's Avatar
I'm in Ontario and it's 85 degrees here.....
Used to live in Winnipeg, and I've seen it get to 90 there too...
Guess things have changed haha
Old May 28, 2010 | 01:10 PM
snopro31's Avatar
im north west of winnipeg. 500+kms away. weather is always diff here then down there.
Old May 28, 2010 | 09:41 PM
Tuttled's Avatar
another 60 ml of rain in Saskatoon this weekend and snow tonight, frost on Sat and Sun night..My weekend to work, dought if I will need the 4wd
