stock fuel injector size?
Old May 20, 2010 | 09:43 PM
Zbl1077's Avatar
what is the stock fuel injector size on the 5.4L? I wanna go up a notch but dont know what lb. they are. I have a 2008 Ford F-150
Old May 21, 2010 | 06:48 AM
05RedFX4's Avatar
24 lb/hr for the 5.4 don't know what the 4.6 is.
Old May 21, 2010 | 07:12 AM
Windsor's Avatar
You can't just swap injectors. You will need a tune to accommodate the correct parameters. Unless you've put some significant power adders on your truck - ported heads with cam or forced induction, it's not necessary. If you want to change fuel metering, talk to a tuner.
Old May 21, 2010 | 02:02 PM
Zbl1077's Avatar
well all i have is piddley things done to my truck, edge tuner, high flow mass air meter, CAI, throttle body spacer and exhaust. thats prob not much of a gain in hp just seems sluggish sometimes. thanks for the advice though
Old May 21, 2010 | 04:30 PM
Windsor's Avatar
If you're not tuned for the high flow MAF and CAI, you need to have that done. The routines reported by the MAF are critical to proper fuel metering, load, etc.
Old May 22, 2010 | 12:33 AM
Bigger injectors are not going to pump more fuel. The ECU is controlling fuel delivery. The only time you need to put bigger injectors in is with heavy mods when the injectors finally reach the limit.
Old Jul 30, 2013 | 05:22 PM
blingbling956's Avatar
I got a question. I have a fully functional ram air hood with the filter and added an additional air intake and also made it forced induction. The thing is when I added the intake my truck didn't gain more power and it shuts down when I'm at a red light. I was wondering if it is because with so much forced air through the ram air hood and intake that maybe it needed bigger fuel injectors.
Old Jul 30, 2013 | 05:44 PM
What engine and year? You will not gain anything without a proper tune. Making air and fuel available does not mean the computer is going to use it.
Old Jul 31, 2013 | 04:04 AM
Does all intake air go past the MAF or did you tap in after it?
There's nothing you can do that will need bigger injectors without supercharging or turbocharging it.
Old Jul 31, 2013 | 08:24 PM
It's a 05 f150 5.4. All the intake air goes through the MAF
Old Aug 1, 2013 | 03:06 AM
You are running lean but it has nothing to do with injectors. The MAF gets confused when you modify the intake and you need a custom tune.
Old Aug 7, 2013 | 10:28 PM
Does my exhaust have something to with it cause I have dual exhaust 3 inch pipes two super 44 flow masters with two 5 inch stacks?
Old Aug 8, 2013 | 11:18 AM
No.
Old Aug 8, 2013 | 11:52 AM
pictures please....
Old Aug 9, 2013 | 12:03 AM
I'll post some new pictures later cause my laptop broke down.
