Swapping Climate Control Module w/Defrost
Old May 19, 2010 | 10:42 PM
Merty's Avatar
Couldn't decide if this was an electrical question or an 04-08 question.
Hopefully this wont be too long of a question, it will be 2 parts. I have an 05 FX4 that does not have defrost, TCS or a reverse parking switch. Just bought 08( I think) FX4 trim piece climate control switches w/ defrost. It also has a TCS switch and Reverse Parking switch on either side of the cig lighter.
Here are the part numbers listed on the climate control(kinda confusing for me)
4L3H-19808-BH (dtd 11/15/07)-from this date is why I think for an 08
7L34-19980-BA / 7LBA135418
So here are my questions.
Can I just swap them out? Will the plugs be the same?
Is my truck prewired for defrost?
Since the new controller has defrost and I plan on adding 09-10 Tow mirrors. I know it will require some wiring but will it work for them?
Part Two-The Switches
I have neither the TCS or parking sensor options.
I am not sure if TCS was an option in 05 but I think the parking sensor was. Would my truck be prewired for at least the sensor so I can send power to a relay instead of the sensor?
I would like to use them for my Aux lights to keep a stock appearence. I have a Hella grill with lights and KC daylighters(Thanks Lush!). I would like the switches to work with the dash lighting(not sure if are even supposed to light up). TCS is a 6 pin switch and the Parking is a 5 pin.
Thanks for any input.
Old May 20, 2010 | 02:19 AM
sbchris's Avatar
Check with Tasca ford parts. I think Tasca said I needed a different fuse box as the defrost is not on our trucks if they were not equipped with it.
Old May 20, 2010 | 09:03 AM
Merty's Avatar
Thanks sbchris. Did you want to add tow mirrors w/defrost also?
Looking at some pics of dashs, I think the new piece is for an 07. It has all ***** and no LEDs. Unless the button control/LED read-out ones are for a specific models(HD,KR?). Depending on which part numbers one starts with 7 and one with 4, I am leaning towards its for an 07. The manufacture date threw me off but I realized it was never installed and had been sitting on a parts shelf.
Old May 20, 2010 | 12:34 PM
sbchris's Avatar
That was my plan as I frequent tahoe a good amount. It is a real pain in the rear to get my mirrors visible sometimes after they freeze over.
Old May 20, 2010 | 12:46 PM
City of Champs's Avatar
the control unit itself should just plug in, as far as your harness having the wiring to everything else i doubt it. everything can be added though or the tcs switch modified to work with some wiring diagrams and a relay placed somewhere else.
Old May 20, 2010 | 05:23 PM
Merty's Avatar
Thanks City of Champs-Just to make sure I understand. The plugs the same, but the defrost wire/pin just wont be on my harness. Or is it there but has the wrong fuse box like sbchris stated.
I figured I could get the switches working, I just dont know what pin does what. I am working on getting the plugs w/wires to make it easier.
Old May 20, 2010 | 10:37 PM
blackjack8900's Avatar
This should be everything you need to know, but just say if you got some more questions
https://www.f150online.com/forums/20...ails-pics.html
Old May 21, 2010 | 12:32 AM
Merty's Avatar
Thanks-That link is on the money! I didnt find it on the search. I did read thru installing Tow mirrors which mentioned this and gave me the idea but no details like your write up.
Didn't originally plan on doing it, I bought the trim piece for the TCS/Parking switches and it just happen to have the climate controls w/defrost with it. It came with an ash tray also, so I can mod that for my edge. Now I gotta save up for the tow mirrors and fuse box.
Just gotta crack the code on those switches.
Old May 23, 2010 | 01:34 AM
I'm assuming switching out a fuse box would be a huge under taking wire by wire. I would make my own circuit outside, with an online fuse and relay mounted wherever.
