Need Help Bad.........Confused
Old Apr 19, 2010 | 02:17 PM
mhail24's Avatar
Question Need Help Bad.........Confused
I have a 2007 F150 with a 4.6l. The other day while driving all of a sudden the engine started to vibrate real bad and act like it was bogging down every time I would hit the gas.I changed the Fuel filter,and the Plugs. Still doing it.It starts and idles fine, it is only when I give it any gas that it boggs really bad.There is no check engine light on and the Cpu at Autozone picked up nothing.Any Ideas would be helpful......................
Mike
Old Apr 19, 2010 | 02:30 PM
Sounds as if it's a throttle body problem. That would be my first guess.
Was it doing the exact same thing before you changed the plugs?
Old Apr 19, 2010 | 02:53 PM
mhail24's Avatar
did not change a thing.
Old Apr 19, 2010 | 02:55 PM
Then I would try cleaning the throttle body and see if it helps.
Old Apr 19, 2010 | 03:06 PM
And shoot the MAF sensor with MAF cleaner
Old Apr 19, 2010 | 03:10 PM
That certainly won't hurt a thing, but if it is idleing ok, I doubt the MAF is causing his problem.
Old Apr 19, 2010 | 06:27 PM
Could be clogged cats.
