weird viberation
Old Apr 7, 2010 | 03:53 PM
themarcus's Avatar
http://thrashdriveshaft.com/Truckhtml/Ford.html
If the driveshaft is the issue then has anyone dealt with this company?
Old Apr 7, 2010 | 04:55 PM
minus_13's Avatar
Heard a lot of good things about them, themarcus.
Old Apr 7, 2010 | 05:35 PM
95sw21's Avatar
and the survey says......
stuck e-brake!!!!!
I found out because when i left work I found my ebrake partially depressed (probably accidently hit it) and as soon as i got on 28 near my office it started to viberate. I hit the ebrake several times and it eventually quit viberating but it still was dragging. So as soon as i got home i disconnected the cables and played around with the levers going into the brake assm. Drove it and no viberations and no dragging! The trans recently felt 'funny' and that is gone too. So hyped!
now to actually fix it... lol
thanks for all the info yall!
Old Apr 7, 2010 | 08:20 PM
nellasemaj's Avatar
vibration
Yes. Check the e brake,mine was repaired under warranty,when I did the rear brakes one drum was really shiny from pads dragging.
Old Apr 7, 2010 | 11:03 PM
minus_13's Avatar
Awesome! Glad you figured it out... It's an easy fix to lessen the tension at the drum/disc. A quick search should find it.
Old Apr 7, 2010 | 11:18 PM
jimmy k's Avatar
good deal. glad that's all it was
Old Apr 8, 2010 | 08:17 AM
Irish FX4's Avatar
Nice one! Its amazing how much vibration the e-brake can cause.
Glad you got it figured out!
