Leveling 101...Simple Question
When I buy my truck, I want to level up the front with the back. What size is recommended and what mfg do you guys recommend?
Truck is an 06 STX 4x4.
Thanks.
Thanks.
Autospring all the way www.autospringcorp.com They come in four sizes 1.5" 2" 2.5" and 3". Measure your truck and see how much lift you need to get the amount of level you want and order accordingly.
Do you have to add anything to the rear or can it stay stock? Im really just looking to match the front up with the back...
It definitely pays to measure first.
I recommend 1.5 just to kick the front up a bit, or you can just take the block out the rear to level.
I saw on Autospring's website that they recommend an aignment after doing a level. Is that necessary or is it just that you should check to see if you "need" an alignment? The truck will have all brand new wheels and tires.
