Leveling 101...Simple Question
Old Apr 3, 2010 | 01:01 PM
rms8's Avatar
Originally Posted by captnick
I saw on Autospring's website that they recommend an aignment after doing a level. Is that necessary or is it just that you should check to see if you "need" an alignment? The truck will have all brand new wheels and tires.
You * A B S O L U T E L Y * will need an alignment after installing ANY size/make spacer.
MUST HAVE AN ALIGNMENT!
Old Apr 3, 2010 | 03:51 PM
captnick's Avatar
Ok thanks. I measured the truck and the front is about 2.5" lower than the back. In that case I will probably go with a 2" level.
By the way, this is my new truck!!!!!
Old Apr 3, 2010 | 11:21 PM
gcart's Avatar
Good lookin truck. what do you have planned for tires and wheels.
Old Apr 3, 2010 | 11:26 PM
captnick's Avatar
Black ATX Mojave 17's with BF All-Terrain 285's
Old Apr 3, 2010 | 11:27 PM
jdruzik's Avatar
I have an '07 with a 2" AS leveling kit... This is what she looks like...
Old Apr 3, 2010 | 11:41 PM
captnick's Avatar
Love the truck jd...f*ckin sick bro
Old Apr 3, 2010 | 11:52 PM
jdruzik's Avatar
Thanks, I love my STX...
Old Apr 5, 2010 | 06:06 AM
roush99's Avatar
i have the 3" from hbc thinking about changing it to a 2.5. uper a arm when jacked up just touches the spring i think it is putting everything on to much of a bind.
Old Apr 5, 2010 | 06:18 AM
gcart's Avatar
my 2.5" does the same thing. my brothers 2" does the same thing.
Old Apr 5, 2010 | 06:42 AM
roush99's Avatar
thanks gcart.how do u get a pic come up when u post?
Old Apr 5, 2010 | 08:45 AM
gcart's Avatar
www.photobucket.com
create an account. its completely free. upload your pictures. you will see 4 different codes under all your photos. copy the IMG code. paste the code here.
Old Apr 5, 2010 | 10:08 AM
dbhost's Avatar
I've got the 2.5" on my '04, and it is a shave tail high. But nothing like the OEM nose in the weeds stance. I like a SLIGHT rake to a pickup. Ford just puts too much of one on these...
I believe you said you are shooting for an '06, which had a slightly shorter tail height than the '04-'05. I would go with a 2"...
As far as MFGs go, I have had Autospring in mine since '06 no problem at all..
Old Apr 5, 2010 | 10:22 AM
95sw21's Avatar
i wonder if lariats are different. I did a 2.5inch autosprung and the back end was 1inch lower. I did lift shackles and it made it level
Old Apr 5, 2010 | 12:09 PM
dbhost's Avatar
Suspension / ride height should be the same for them. Trim level not relevant. Did you get your Lariat new, or close to new? It's possible the rear springs sagged, or a prior owner swapped the block with a shorter one...
Old Apr 5, 2010 | 01:27 PM
captnick's Avatar
I just measured my truck, and the front is about 2.5" lower than the rear. I will probably do a 2" level. I dont care if its still a tad lower but I deffinitly dont want it higher than the rear.
