Ford brand rear diff fluid.
Old Mar 21, 2010 | 01:35 AM
AAK625's Avatar
Question sdfsdfsd
ghfffghfg
Old Mar 21, 2010 | 05:03 AM
It's Motorcraft 75w140 full synthetic. It's not critical to use only that brand.
http://k-mansparts.com/items/super-d...0ql-detail.htm
Old Mar 21, 2010 | 09:36 AM
I bought the MC 75w140 for the rear end at my Ford dealer as well as the friction modifier. Be sure to use the friction modifier if you have limited slip rear end.
If you're 4wd, the front you can use 75w90 or 80w90 synthetic.
Old Mar 21, 2010 | 11:56 AM
In response to your private message:
Standard Differential, Rear......GL-5
ALL TEMPS......75W-140 [1]
Limited Slip Differential, Rear......GL-5
ALL TEMPS......75W-140 [1] [2]
Differential, Front......GL-5
ALL TEMPS......80W-90
[1] Synthetic oil is required.
[2] Limited Slip Identification: Letter & number
on plate on door lock pillar. (Models W/ Traction-Lok Rear
Axle Add 4 oz of friction modifier part no. C8AZ-19B546A
(EST-M2C118-A) or equivalent)
If you have aftermarket gears, limited slip, or locker, follow the aftermarket manufacturer's recommendation.
Have you read your owner's manual? If you don't have one, you can download it.
http://www.fleet.ford.com/maintenanc...ls/default.asp
Note that synthetic is required in the rear, not required in the front, but you may use synthetic in the front.
Old Mar 21, 2010 | 06:03 PM
ZEEKA's Avatar
So the differential fuid comes as a synthetic straight from the factory?
Old Mar 21, 2010 | 07:44 PM
AAK625's Avatar
gthtgh
Old Mar 21, 2010 | 07:52 PM
Ah, cool. Be sure to post pics with the new cover.
Old Mar 21, 2010 | 11:18 PM
sam1947's Avatar
Originally Posted by AAK625
I have the Detroit TrueTrac back there, so I don't use the additive. The installer threw Royal Purple in there and it's been grinding for the past 6 months. I want to go back to stock fluid when I get the Mag Hytec cover installed.
I also have the True-Track in my 07 w/Mag-Hytec cover. I am currently running AMSOIL 75-140 Syn with no problems, but I think I will change it out and replace it with LUCUS 85W-140 non syn gear oil as recommended from Eaton/Detroit. You will need 5 qts with the new cover installed. Brings the level right in the middle of the dipstick.
Old Mar 22, 2010 | 10:08 AM
Eaton recommends standard NON synthetic 80W90 - and correct, NO additive.
I'd advise you get the RP out of there and put what Eaton recommends in it.
Yes.
Old Mar 22, 2010 | 07:17 PM
AAK625's Avatar
fdgdfgsd
