Is it easy to change coil and boots for spark plug?
I doubt they will suggest changing the COPs. They are long life and you would be getting engine codes if they were bad. However, the boots are a different matter. They are made of rubber and tend to crack or get brittle from the heat, if you have a lot of miles. They are expensive at the dealer, about $100 for the set, but they normally do not charge extra labor as they are taking them off anyway, to get to the plug.
