Cruise Control not working
Old Mar 19, 2010 | 03:48 PM
redryder05's Avatar
Hey folks,
After installing my new Pioneer HU the brake light stays on and the cruise control won't work. I looked at the fuses and they're fine. I traced the wiring diagram back to the Brake Pedal Position Sensor and I'm thinking that's the culprit. I also have a parking brake bypass installed for the HU but don't think that has anything to do with it. I also checked the brake lights, no issues. If anyone has any input, it is appreciated.
Old Mar 19, 2010 | 04:46 PM
ChrisAU's Avatar
I'd bet you cut the wrong wire to install the parking brake sensor.
Old Mar 19, 2010 | 04:48 PM
ChrisAU's Avatar
Make sure the wire you tapped into is the positive wire coming from the plug that plugs into the top of the actual parking brake pedal, not the regular brake.
Old Mar 19, 2010 | 08:21 PM
redryder05's Avatar
Didn't cut anything tapped in to the Green\Red Stripe wire on the parking brake sensor. According to 12volt.com, that is the positive side. My HU pops into camera mode so I know I got it right.
Old Mar 20, 2010 | 01:50 PM
If the brake light stays on, the cruise is not going to work, it thinks the brake is depressed. Whatever you did, you did something incorrectly.
Old Mar 20, 2010 | 02:38 PM
Tylus's Avatar
what did you tap into on the parking brake?
you did the bypass right? so you shouldn't have anything touching the parking brake.
and what did you use to trigger the reverse camera mode?
I would suggest you remove all the wires you connected down there and see if you get the cruise control back. then re-evaluate your connections and see what was messed up
