spark plug nightmares
On Feb 17-2010,i guess i was one of the lucky owners.I have 28,000miles and decided to change plugs.I was told by alot of F150 5.4 owners to get Champion plugs and new coils.I had no problem taking those plugs out.Plugs looked new also.I used Aerokroil penetrating oil,opened the plug a 1/4 turn shot sum oil around plug and let it set for 5 min.Plug # is 7989.Engine was luke warm.I bought Accel coil packs as a kit from Jegs $232.00-part #140033-8.Dont spray alot of penetrating oil around plug because it will Vapor Lock the engine...i thought Ford had there **** together..i owned 2 Dodge Rams 1999&2001...No issues!!! i guess live and learn...Paul from Buffalo,NY
With the knowledge of how to extract the broken plugs, it is not usually the nightmare it was when this problem was first discovered.
I'm going to do mine in the spring when it warms up. So if i break a plug i can ride my supermotard to work. Im going to do mine the way Quintin does them. 14.4 volt Cordless impact gun. The way i figure is if there gonna break they will break no matter how care full you are. So im gonna give em hell and hope fully they pop right out. From what i have read there seems to be a high success rate doing them this way.
So let the game begin come spring. I will post my out come then.
Yes, he is. Several have with success. Look up Quintin's posts. He is a Ford tech at a dealership and that is the way he does them.
Ill look up the post, thanks.
I think the jarring must help break the carbon loose. As I recall, he says that with a luke warm engine, he breakes each plug loose 1/4 turn. Let's them soak with carb cleaner for about 15 minutes, then puts a cordless impact on them till they come out. He says it takes about 2 hours to change them. You have to remember, if one does break, it's not as big a deal as it was initially. There are now retrieval tools for the broken parts. I have to assume that is the way they do it at my dealership, otherwise, how would they change a set in about 2 hours?
i have a shop here who explained to me how he does it. he just soaks them in pb blaster, then takes a breaker bar and loosens them about 3 or 4 inches then tighens them again another inch, then loosesn 3 -4 then tightens. so on a clock hes starting at say 6 o clock,going to 3 or 4, then he comes back to 5, then to 2 or 1 then back to 3/4, he said if you just take a ratchet and unscrew them thats what breaks them.
Haven't broken one since.
Quote:
Originally Posted by A DuB
I cant sense sarcasm on a message forum. Are you seriously considering using an impact gun on spark plugs?
Yup, I do.
Yup, I do.
Fortunately I got all mine out (the plugs, not my hair) in one piece 15 months ago at 48,000 miles following the tsb and the super-slow, back and forth method. If I knew then what I know now, I would have given the impact gun a shot.
Oh yeah, the Champions I put in are working fine.
Why change at 28K miles?
The suggested change is 100K miles. I changed mine at 110,000 and they looked fine. Mine came out easy. Just took about four hours, lots of curse words and a tremendous pain in the ****. I keep hearing we should use motorcraft only.
Also - without actually measuring the gap, you can't know for certain if the plugs look fine - barring any gross damage such as missing electrodes
Folks typically change them sooner on these trucks as the success rate usually goes up without undo breakage. And for me personally, I do not happen to believe any plug can last and function efficiently at that mileage.
Just my humble observations. Thanks for not flaming me.
Regards & cheers!
MGD v2.1d
