New to F150Online
New to F150Online
Hey guys,
New to the forum, I got a 04 5.4 xl. Im looking for a leveling kit but dont know which one is best, also looking for brighter headlamps any hints or ideas would be nice.
Welcome. And what they said plus the brighter headlights is solve by adding HID's
you will need the entire kit for the hid bulbs to work and don't just try and get higher wattage bulbs because the can burn the housing and or wiring.
There's more than one way to level a truck. Some lift the front, some drop the rear. If you don't care to be tied into running larger tires to compensate for lift, you might look at dropping the rear. It's a thought that hadn't occurred to me when I lifted mine. Beside spacers, Rancho and Bilstein both make front struts with revised spring seat locations that are good for 1"-2" of lift.
Lot of guys will recommend HIDs, but installing a HID bulb in a halogen housing is illegal. Sylvania and PIAA both make brighter halogen head lamps. I'm running the PIAA Extreme White bulbs and more than satisfied with their performance.
