Rear end squeaking and squealing loudly (04 FX4 SCREW)
Old Jan 18, 2010 | 09:33 PM
AAK625's Avatar
Arrow Rear end squeaking and squealing loudly (04 FX4 SCREW)
Hey everyone, hope you're all doing well. For the past week and a half the rear end of my truck (86k mi.) has been squealing, squeaking, and creaking very loudly whenever I start moving the truck, especially when it goes over uneven pavement or bumps. So far it is only present in the rear of the vehicle, mostly on the right side.
Thanks in advance,
Anthony
Old Jan 19, 2010 | 04:32 AM
Impact9's Avatar
Hey Anthony. Get under the truck and do some leg presses or find a fat gal to jump on the bumper. You might have a loose leaf spring, bad shock, or bed bolt.
Old Jan 19, 2010 | 09:17 AM
AAK625's Avatar
I'm 160ish. I was jumping on the bumper last night like a crazy man and I heard nothing. I'll try to get under there today.
Thanks.
Old Jan 19, 2010 | 10:00 AM
You could have a cracked leaf springs, or the shims between the leaves might be damaged.
One way to test it is by spraying WD40 or PB GDL on them... do it on one side at a time. This way you will find which side it is coming from.
I've got squeaky leaves on my Dakota, and I am going to be replacing them this year with custom leaf springs.
Old Jan 19, 2010 | 03:48 PM
Sleadstorm's Avatar
You might want to check your u joints my 04 f150 heritage started doing that and i relpaced u joints and every thing is quite now
Old Jan 19, 2010 | 07:01 PM
Silver04f150's Avatar
def check the u-joints, mine are squeeking too
Old Jan 19, 2010 | 07:21 PM
I find that the leaf clamps on my leaf springs creak and squeak. I spray some seafoam deep creep and top it off with some white lithium grease to stop the creaking and squeaking, and this now regular PM for the truck every three months or so now.
Old Jan 20, 2010 | 12:14 PM
AAK625's Avatar
It's going into Ford on Friday for regular service, so I'll see if they'll take a look at it without charging me out the butt.
Old Jan 22, 2010 | 09:48 AM
AAK625's Avatar
Well, according to Ford, I have bad right front shock. One of the Bilstein 5100's that I haven't even had for a year went bad from highway mileage?
