57K On a 2004 and no tranny problems yet, I think...
Old Jan 14, 2010 | 04:44 PM
plmn's Avatar
Originally Posted by bambo2888
Well, in addition... your "tranny fund" will cover only the tranny, meanwhile, the same priced ESP will cover a lot more than just a tranny... it seems like a no brainer to me, especially considering how mnay forum member will atest to their transmissions needed service.
It's only a no-brainer if you assume it will go out. Even with all the reports here it's still more likely to be fine than to go out.
ESPs are profit makers. If you keep buying them, odds are almost certain you will come up on the short end in the long run. I wasted thousands on ESPs for three vehicles before I came to my senses.
Bottom line is that if I felt any vehicle was so unreliable that an ESP is a must, I would either sell it or not buy it in the first place.
Old Jan 14, 2010 | 05:42 PM
edgespeeder06's Avatar
well good info. I'm still half and half on it. I take care of my truck. did the tranny fluid at 43k as soon as i bought it from the other owner.....planning on changing out all the fluids in the spring if that helps....runs strong....fixed the IWE Solenoid issue so now I have no problems with it.
Old Jan 14, 2010 | 06:27 PM
Silver04f150's Avatar
It definatly depends on how the previous owner drove it... I have 108,000 miles on my 04, no issues
Old Jan 14, 2010 | 10:26 PM
tim98's Avatar
Theses transmissions are not "known" to be bad. Ford has done pretty well in the past 10 years with their transmissions. The reason you "always hear about them going out" is because no one ever talks about the transmission doing great. Don't assume a product is bad because you see alot of people saying how bad it is on a forum that is used to bitch about our trucks.
The Esp is worth it if it gives you a piece of mind and if you can't or won't do the work yourself.
Old Jan 14, 2010 | 10:44 PM
bjp207's Avatar
Mine went at 67k, my truck was previously leased and I don't think it was well taken care of, I could have paid for 3 esps by now with all my issues
Old Jan 15, 2010 | 05:36 PM
05BlackFX4's Avatar
you want a bad tranny...go buy a dodge....my brother in law had an new 02 diesel quad cab...4 trannys in less than 6 years....he was deployed in Iraq and Afghanistan and my sister had 2 go out on her....got rid of the truck with 52K on the clock.
Old Jan 15, 2010 | 06:21 PM
oh definitely depends on the ESP and what exact stuff it can cover. Will find out next time i drop by ford
