Problem previously not seen.
Yea, coils are load sensitive, that's for sure. Have you ever had injector problems in the past? Surprised I don't see any mention of that, since the 05 was the model year for those issues.
I'd have to go with the majority on this one tho, - coils. I wouldn't rule out a fuel issue yet.
Good Luck Blue.
Good Luck Blue.
Good Luck Blue.
Good Luck Blue.
Truth be told, I would start with the fuel filter myself, - I don't like to let it go that long. When they go bad, engine reaction doesn't always follow theory, they can fool yuh
Since the injectors have a 100,000 mile warranty, it might not hurt to have them checked. Thing is, I'm not sure how the dealership works that ? If it's totally cost free lol. I would have to call them and inquire.
Truth be told, I would start with the fuel filter myself, - I don't like to let it go that long. When they go bad , they don't always follow theory, they can fool yuh
http://ww2.justanswer.com/uploads/ti...call_07M08.pdf
My experience is when one goes it goes, no warning. Blue's experience sounds like something different in comparison.
I like the go back to stock tune as well. You could go back to stock/ re-boot/ run it for a bit/ re-load your tunes or how ever you do it and see what happens; - I haven't run custom tunes yet myself . PCM's can get buggy tho.
blue the reason its the coils to blame, is from a stand still, you work up through the RPMs, where as when you downshift, you go from 1700 to 4500 pretty instantly and the coils cant respond to the speed change quick enough
If you need help doing the coils let me know
