Frost on the inside
Old Dec 24, 2009 | 07:36 AM
Ricky Bobby FX4's Avatar
Frost on the inside
how does my truck have frost on the inside of the windows. Its like 14 deg but I have never seen this happen before any thoughts, thanks
Old Dec 24, 2009 | 09:21 AM
mkosu04's Avatar
run your defroster more to reduce the humidity in the truck... chances are you had warm moist air inside from breathing and whatnot... then after you parked for the night the windows cooled down and as the air cooled the moisture condensed out of the air and on the windows.
It happened to me once... I think it just takes an odd combination of factors to create.
Run defrost more often and it should fix it!
Old Dec 24, 2009 | 09:24 AM
bjp207's Avatar
If your floor is the slightest bit wet it'll happen all day long
