automatic folding mirrors....
Old Dec 22, 2009 | 10:17 AM
SSCULLY's Avatar
Originally Posted by CcHARLEYcC
nothing to confirm?
Sorry I am a bit confused, what is the question getting at ?
If it is the delay install, I am still trying to figure that one out.
The cost is getting out of control with it.
The ELK-960 does not do what I need it to, and the Square D JCK relay is too expensive to make it doable for all.
If I don't use the JCK, it is going to be either 2 more ELK-960s or something along those lines, which the starting cost is ~ 90.00 for the autofold with delay.
Maybe I should ask, what is the highest cost for the autofold with delay someone would want to pay ?
Keep in mind the autofold part already requires 1 ELK-960, which is in the 25-30 range ( saw 1 listing for 19.95, don't know if I trust that listing ) + S/H, add to this the splices and wire, and the autofold modification is in the 40-50 range, depending on what you already have at home.
The autofold w/ delay with 3 ELK-960 relays is going to be in the 100.00 range, and the autofold delay with the JCK relay will be in the 180.00 range ( and less moving parts / easier install ).
I am trying to keep the cost of the parts members have to source for the install at a reasonable price.
KEEP IN MIND : This is a DIY install, I do not sell any of this, I am just supplying the diagram and the help with the install.
Trying to look from the outside in, a parts list of 180.00 I thought was too much for this, maybe I need a reality check on that.
Old Jan 12, 2010 | 07:59 PM
tom81's Avatar
G'day guys,
I'm not an F150 owner, although I do share a similar interest on this topic...
http://www.skylinesaustralia.com/for...t-t295040.html
Fords and Nissans might share a similar design with their wing mirror extend/retract feature. If this is the case, I might be able to give you a little help on the subject.
Goodluck. Keen to know how you go with it!
Cheers.
Old Jan 13, 2010 | 05:59 PM
CcHARLEYcC's Avatar
I'm very interested in doing this but diagram really is not too easy for me to follow.....
Old Jan 26, 2019 | 10:12 PM
KR2Wheel's Avatar
Originally Posted by SSCULLY
With the information on the button press and hold operation, this is the diagram for no delay, fold / extend when the door is opened.
This is using the Elk Security delay relay-960. The price seems to be 25-30 each for them.
I want to recheck the delay operation diagram 1 more time prior to posting. This setup would require 2 ELK-960 delay relays.
9 years ago but still current thanks for the write up I ordered my relays and will post when finished
