will not start cold!!!
Old Dec 16, 2009 | 12:11 PM
jp04fx4's Avatar
My 04 f150 fx4 will not start cold. I will have to turn it over for 10 min or so to it did to start. I replace the fuel filter. that it not help. If you turn on the key you can hear the fuel pump turn on. does any Know how to check fuel pressure? or has anyone had this promblem? what is the box on the fuel rail? help!!! thanks jp
Old Dec 16, 2009 | 04:56 PM
05Bluefx4's Avatar
How are your plugs?
Old Dec 16, 2009 | 05:35 PM
jp04fx4's Avatar
plug are ok i think. it runs good when you get it started. thanks jp
Old Dec 16, 2009 | 06:22 PM
FasterDisaster's Avatar
How cold is it getting where you are?
Old Dec 16, 2009 | 06:35 PM
x2 how cold is your area? If its below zero you may want a block heater.
Old Dec 21, 2009 | 07:33 AM
Yeah, that's what I was getting at. Where I am it gets to be as low as -50 Celcius (-58 F), and if I don't plug it in overnight you can pretty much count on it not starting the next day. With a block heater it fires up no problem though.
