Gas Gauge not reading correctly
Hey guys... last night I went to the gas station with about 8 gallons of gas in my tank. I topped it off by adding 18 gallons into it. When I started the truck back up now all it shows on the gauge is a half tank. It does raise slowly, but raises quickly to a half tank when it starts up. I know it is full because I put the gas in it. Any ideas? It is a 2008 F-150 Supercrew. I figured I would wait a few days and go to the dealer under warranty but thought I would ask you guys. It is about 20 degrees here right now. Thanks!
Scott
Scott
Don't worry, it just the anti-slosh sensor playing with the computer. I did this when I filled up. 24 gallons and said I was still on the E. Yeah, big worry there since I just bought the truck. Leave the key turned all the way off when you fill up and shouldn't have a problem. It will raise slowly with each start and as you cruise around. Took 5-6 starts and like 15mins of straight driving the time I did it to go from E to F =P.
Strange.....I did a search and read a few threads on this.
Mine is doing the last 2 fillups. I filled up last night with less than 1/4 tank. It stayed below 1/4 tank last night and this AM after a couple of starts.
On the way home this evening it was showing about 1/2 tank.
I don't think I've ever had my key in the ingnition while fueling.
I found one thread whey someone suggested turning the ignition on and off 8 times. Then turning on for 8 seconds .....then off. This procedure was said to reset the ECM. Well.............didn't change anything for me.
I would like to know what the problem really is.
