Horn Broken
Old Dec 12, 2009 | 03:11 PM
brownchristian's Avatar
Horn Broken
My horn just quit working yesterday. Checked the fuse and it is good. Do the horns just break? What else should I check before I take it in?
Old Dec 12, 2009 | 06:01 PM
bjp207's Avatar
Check connections at the horn, check the horn for voltage, test the circuits
Old Dec 12, 2009 | 06:09 PM
Tbird69's Avatar
Stop with the road rage and the horns will last longer.
It's not unusal for them to quit working although it is rare. Pull the connector and connect a test light between it and a good ground, then have a buddy press the button. If it lights then the circuit is good. I believe there's a relay under the hood or on the fuse panel, that could have quit too.
Old Dec 12, 2009 | 06:39 PM
BrizzleOrizzle's Avatar
"horn broke watch for finger" takes on a new meaning for you.
Old Dec 12, 2009 | 06:52 PM
tsunamimike's Avatar
i'll trade ya horns mine would never stop beeping. i believe something got wet, so i just took the fuse out haha it used to wake me up in the middle of the night so if anyone has ever had this problem and might know what it is let me know
Old Dec 26, 2009 | 09:05 AM
Wanted to post an update. Apparently when I was cleaning the mud out of the fender wells the high pressure sprayer blew out the connector at the horn. Plugged it back together and it all works again.
