Brake fluid capacity
Well, I searched for this very answer, only to find this thread with, well..........
I need an idea of how much fluid it's going to take to completely flush the system. I know the system can't hold a whole hell of a lot, just not sure how much to have on hand with the waste that will come from the exchange.
Wouldn't normally be a problem, but I'm ordering AMSOIL fluid and would hate to be stuck there with not enough fluid to properly finish.
When I changed my brakes I did this very thing. I basically bled each caliper until the fluid flowed clear, and then a little more. I went though one full quart then ending up topping up the master cylinder with a little bit of a second quart.
if you just do it 3-4 bleeds per caliper you will be fine with one quart.
HAHA thanks guys.
I was just about to order the fluid and thought I would check in before I entered the quantity. I had previously estimated about 5 qts to get it clean, guess I was a bit off. Glad I checked here first.
