Tie Rod-How to check for condition.
Hey guys,
As the title states, I know that this may be a dumb question but what do you look for when checking tie rods? How do you know that they are going bad?
Thanks!
Thanks!
The easiest way is to look for too much play. Have someone move the steering wheel back and forth a tiny bit, slowly. Watch the relationship of the tie rod to the spindle. If you can detect movement between the two, it's gone. That would be an indication of excess play. You could also unbolt the tie rod, separate it from the spindle and check it for excess play by hand.
When mine went bad, I could actually here the front end "give" a little when say going over curbs or large bumps. New tie rod is only like $65. and has a grease point unlike the factory! Also if it is bad, it is likely your alignment is out also.
I have 78,000 on the truck. They were replaced around 50ish. I spend a lot of time on logging roads, and I know the bumps and abuse brings there live down. I am assuming you always have to get a alignment after tie rods are replaced? I don't believe I have any. I need to have the girlfriend turn the wheel back and forth while I take a look though to verify.
Thanks for the help.
Ryan
Ryan
if it pops when you turn i assume it is broken or bent correct? sorry to get in your thread but i was about to ask a question about tie rods.
also if you are afraid of breaking up the new stock tie rods you might want to look into these, i am planning on buying them within the month for my truck.
http://bulletproofsteering.com/fordpricingoptions.html
Holly crap, you ain't kidding.
My eyes My eyes! Someone should tell him how much business he is losing by having that absurd web design.
