Considering a longer Front Shaft....................
Anyone with a 6" lift get a shudder in the steering wheel when in 4X4???? I took it to the shop today and they told me that i need a longer front drive shaft....so i went to my local 4 Wheel shop and they recommended the Pro Comp front shaft.........anyone have this problem and if so what did you do to fix it?????
Just don't wanna spend $300 if i don't have to.....
I had that problem with the front and rear.
I think I spent 430ish for a custom double cardan joint driveshaft for the front. I'm on a RIZE lift.
I think they have pills for that now.........ask Bluejay, maybe he'll spot you some from his stash......
If you still experience vibration in 4x4 at higher speeds, then get it re-balanced.
