2004 5.4L Engine Surge/Shaking/Shudder in Overdive low RPMs
Old Oct 24, 2009 | 03:03 PM
b3ross's Avatar
I was driving down the expressway yesterday and started to get an engine surge/shake/shudder when the truck shifted into overdrive and low rpms (40-55 mph).
The truck runs completely fine at all other speeds, gears, and idle. It just seems to be that initial shift into overdrive at lower rpms.
Finally got it to draw a flashing engine code while the shaking/surging was occurring but the engine light quit flashing when i got off the freeway and the shaking quit...
Was able to pull 2 codes in the history
P0174 Fuel system lean bank two
P0308 Cylinder 8 Misfire Detected
Not really sure what the issue could be. Thinking a possible COP on the #8 cylinder ?.. Any suggestions would be greatly appreciated
Old Oct 24, 2009 | 03:34 PM
dmolaver15's Avatar
i have the same issue but im getting a code for cyl 6
i'll be picking up a COP for cyl 6 on monday and hopefully that will solve my problem. I tried cleaning the MAF sensor, and changing the air filter and those didn't help my situation
Old Oct 24, 2009 | 03:39 PM
b3ross's Avatar
are you only getting the shake/surge in overdrive and low rpms? Please let me know if the new COP fixes this issue.
Old Oct 24, 2009 | 10:27 PM
dmolaver15's Avatar
yes those are the symptoms low rpm's and od between 45-60mph
Old Oct 27, 2009 | 03:14 AM
b3ross's Avatar
Did you have any luck with the COP replacment?... I'm currently out of town and plan on replacing my #8 COP Friday evening.. Really hope this fixed your issue, I really have no other ideas if this isn't the issue
Old Oct 27, 2009 | 10:34 AM
Crstfr's Avatar
TSB for the shudder.. my truck suffers from that now...it happens to everyone... you'll get a flash and it will be back in 2 weeks... you'll just have to live with it.. I've done all the fluids...flushed everything... still shudder... also read to try Dr. Tranny for the shudder fix.. i have some shipping to me today... .. now if someone could help me with the hissing!... see bucking and hissing post!
TSB
05-10-12 HARSH 3-2 DOWNSHIFT BETWEEN 17-25 MPH (27-40 KM/H) - NO DTCS - 4R75E AUTOMATIC TRANSMISSION - VEHICLES BUILT BEFORE 4/20/2005
Publication Date: May 13, 2005
FORD: 2005 F-150
LINCOLN: 2006 Mark LT
ISSUE:
Some 2005 F-150 and 2006 Mark LT vehicles built before 4/20/2005, equipped with the 5.4L engine and 4R75E automatic transmission, may exhibit a harsh 3-2 downshift between 17-25 MPH (27-40 Km/h) with no diagnostic trouble code (DTC), and a driveline clunk between 40-50 MPH (64-80 Km/h).
ACTION:
Reprogram the powertrain control module (PCM) to the latest calibration using WDS release B37.4 or higher. Calibration files may also be obtained at www.motorcraft.com.
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
OPERATION DESCRIPTION TIME
051012A 2005 F-150, 2006 Mark LT, All Equipped With 4R75E Transmission: Check Diagnostic Trouble Codes And Reprogram The Powertrain Control Module (Do Not Use With 12650D, 12650D84) 0.4 Hr.
Old Oct 27, 2009 | 10:46 AM
F150man21's Avatar
depending on how many miles are on it, id bet its the plugs or COP's. probably the plugs.
Old Nov 2, 2009 | 01:24 AM
b3ross's Avatar
Sorry to bug you on this, did you have any luck with the COP on your #6 cylinder?..Thanks for any help
Old May 17, 2010 | 07:11 PM
Golfmanaz1's Avatar
Had same issues, shuddering and surging around 45-50 when it goes into overdrive, but could gas it thru that range with no problem. Sometimes even at higher speeds when you let off gas a little would get shuddering. 151K on truck did plugs around 105K. Ordered COP's from uneeksupply on Ebay, whole set for $114.95. Installed this weekend and problem is gone. Sure glad its not the tranny. definitely check plugs and COP's.
Old May 17, 2010 | 07:19 PM
mSaLL150's Avatar
b3ross, How many miles on your 2004? Probably time to do the plugs and COPs. I recommend custom tuning as well.
Old May 28, 2010 | 07:25 PM
seadog364's Avatar
Ok I'll ask
What the hell is a COP? Wise guys need not reply
Old May 28, 2010 | 07:57 PM
maplesyrup's Avatar
Coil On Plug
Old Apr 14, 2014 | 10:45 PM
gerritvb's Avatar
I have the same problem with my 06 F150 SCrew... I am cheap, where should I start??? Plugs or COPs?
Old Apr 14, 2014 | 10:56 PM
429 boss mustang's Avatar
Of you have a hissing check for a vacuum leak.
Old Apr 14, 2014 | 11:07 PM
gerritvb's Avatar
Please explain... can I do this myself? Any YouTube videos out there to watch? I usually work on mopeds, so this is new.
