PLEASE HELP! changing Fuel filter
Old Oct 23, 2009 | 12:10 AM
SIK-06's Avatar
Exclamation PLEASE HELP! changing Fuel filter
stuck in the middle here. trucks been sitting for at least 3 hours with gas cap off. this is where im stuck. i insert the tool, hear it "click" but i cant get the POS off! what am i doing wrong??
Thanks!
Old Oct 23, 2009 | 12:20 AM
Is it on the side toward the motor? The outlet side?
Old Oct 23, 2009 | 12:28 AM
You work the tool down into the line as far as possible, then hold the filter and pull the line toward it to get it to release before pulling back. Once< i had one that would not releae. Ended up taking it to a lube joint and they had to pull it out. They said that happened when they rusted. They put in a replacement clip.
Old Oct 23, 2009 | 12:33 AM
SIK-06's Avatar
yeah
Old Oct 23, 2009 | 12:35 AM
SIK-06's Avatar
Damn that may be my situation! im pretty mechanically inclinded and this Biotch aint coming off. specially after reading other threads they make it sound like nothing
Old Oct 23, 2009 | 03:16 AM
tjstrike's Avatar
I had alot harder time with the little blue clip than I did on the side that needed the "special tool". I wouldn't think an 06 would have rusted up already, I just changed my 05 out about a month ago.
Old Oct 23, 2009 | 08:20 AM
mhockey9090's Avatar
ill be doing mine soon
Old Oct 23, 2009 | 09:48 AM
I recall you have to push the tool towards the line while pushing the line towards the tool, then pull both together away from the filter.
Old Oct 23, 2009 | 09:49 AM
cstanek's Avatar
Mine was a pain to get off too. I just tried to stay patient (didn't really happen) and kept working at it until it came loose.
Old Oct 23, 2009 | 04:49 PM
SIK-06's Avatar
[QUOTE]I recall you have to push the tool towards the line while pushing the line towards the tool, then pull both together away from the filter.[quote]
I tried that. i've tried every which way i can think of. How far does the tool go in. what size line is it. The tool kit i got has different sizes, i tried it with the grey and blue one.
My patients are gone i was trying for two hours last night. my finger are sore and bruised today. i just dont understand whats not right, and its driving me nuts!
Last edited by Bluejay; Oct 23, 2009 at 04:51 PM. Reason: do not circumvent the language filter.
