Manual back glass replaced with electric? Also adding power windows?
Old Oct 19, 2009 | 09:40 PM
4x4fanatic2006's Avatar
Is this a plug and play kind of deal where I can just run the wiring after it's installed, or will the truck have to be modified a lot? Also, will I be better off buying a power window kit or would it be better to buy the regulators from a wreck yard and run the wires myself?
Old Oct 19, 2009 | 09:43 PM
effects4's Avatar
the harness is already there in my 04, just need the switch and motor/wiring end. There is a write up on here about converting the manual to electric. I think that you just need the motor (and its related items) and overhead switch. Can use the glass that's already there.
I plan to do this but haven't found a junkyard donor yet
Old Oct 19, 2009 | 09:44 PM
for your back window look here
https://www.f150online.com/forums/ar...2004-08-a.html
for your door windows, you will need new regulators, wiring and switches
Old Oct 19, 2009 | 10:03 PM
bjp207's Avatar
I wired mine myself using factory panels and switches, definetly the best way to go imho
Old Oct 21, 2009 | 02:20 AM
UofKboy's Avatar
Here ya go........www.A1electric.com
Highly recommend it.
