unlocking truck at night and lights come on
Old Oct 19, 2009 | 09:17 PM
bankrpt's Avatar
when i unlock my truck at night with my remote my headlight come on is there anyway i can make them not come on im not wanting them to come on because when i unlock the truck it makes my hids flicker and im just afriad ill burn a bulb up or ballast
Old Oct 19, 2009 | 09:31 PM
risupercrewman's Avatar
Good question!!!
Old Oct 19, 2009 | 09:41 PM
05RedFX4's Avatar
This same question has been asked before, IIRC there is no way to turn off the feature to save your HID's.
Old Oct 19, 2009 | 10:03 PM
dilloncawthon's Avatar
mine don't come on when i unlock the truck. is this something that ford stopped doing?
Old Oct 19, 2009 | 10:14 PM
does it do it during the day too?
do you have DRL?
Old Oct 19, 2009 | 10:24 PM
bankrpt's Avatar
no does not doing it during the day unless its early in the morning and no i dont have drl
Old Oct 19, 2009 | 10:30 PM
mblouir's Avatar
Yes there is a way to turn the feature off....I did it for the exact same reason. It's in the manual. Give me five minutes and I'll get back to you with how to do it.
edit-
Originally Posted by F150 Manual, pg. 137
Enabling/Disabling the perimeter lighting feature
Your vehicle comes with the perimeter lighting feature enabled. All vehicle doors must be closed before beginning the procedure. You must complete Steps 1-5 withing 30 seconds, or the procedure will have to be repeated. If the procedure needs to be repeated, you must wait a minimum of 30 seconds to begin again. Note:
All lock/unlock buttons used during the procedure are pressed on the keyless entry fob.
1. Turn the ignition to the ON position, then press the unlock control three times.
2. Turn the ignition to the OFF/LOCK position, then press the unlock control three times.
3. Turn the ignition to the ON position; the horn will chirp to indicate the driver configuration mode has been activated.
4. Within five seconds, press the unlock control two times.
Note: One horn chirp should be heard, indicating the system has been disabled. Conversely, a horn chirp followed by a honk will indicate the system is enabled. Pressing the power door unlock control two times again will turn the feature ON if it was previously OFF, or OFF if it was previously ON. Every two consecutive presses of the unlock control after successfully entering the configuration mode will change the enable/disable condition of the feature.
5. Turn the ignition to the OFF/LOCK position to exit programming.
Note: After exiting the driver configuration mode, the horn will chirp once to indicate a feature has been activated/deactivated.
Old Oct 19, 2009 | 10:36 PM
bankrpt's Avatar
thanks bud i looked but must have over looked it
Old Oct 19, 2009 | 10:37 PM
AAK625's Avatar
I'd also like to know how to stop that AND the interior lights from coming on.
Old Oct 19, 2009 | 10:45 PM
05Bluefx4's Avatar
Nice find! Cant wait to change it tomorrow. I was worried about my HID's also.
Old Oct 19, 2009 | 10:52 PM
mblouir's Avatar
No problem! I actually just made this thread in your honor.
https://www.f150online.com/forums/20...your-hids.html
Give me a minute and I'll see what I can dig up since I've got the manual open.
edit: Just looked and there is no way to disable the interior illumination. It doesn't specifically say there isn't a way, but it is right beside the perimeter lighting feature, and it doesn't give a method to disable the interior lights. I remember checking into the same thing personally before. You'd have to go in and personally wire something up.
Yep I disabled mine before my HIDs even came in. Was really worried about it.
Old Oct 19, 2009 | 10:56 PM
bankrpt's Avatar
yes sir thank you im headed out to the truck right now thanks
Old Oct 19, 2009 | 10:58 PM
bankrpt's Avatar
just did it that was really quick less then a minute lol
Old Oct 19, 2009 | 11:03 PM
mblouir's Avatar
Glad it worked for ya!
Old Oct 19, 2009 | 11:11 PM
bankrpt's Avatar
is there any other neat little features hiding in the manual that you know of?? i did turn my seat beat chime off and now headlights anything else? and thanks for your help
