unlocking truck at night and lights come on
Old Oct 19, 2009 | 11:15 PM
AAK625's Avatar
Originally Posted by mblouir
Just looked and there is no way to disable the interior illumination. It doesn't specifically say there isn't a way, but it is right beside the perimeter lighting feature, and it doesn't give a method to disable the interior lights. I remember checking into the same thing personally before. You'd have to go in and personally wire something up.
What's that lighting the military uses that isn't too visible from a short distance away?
Old Oct 19, 2009 | 11:18 PM
mblouir's Avatar
Those are the only two I've played with so far from the manual. The only other neat little trick I've done is the Bambi mod. It lets you use your fog lights with the high beams.
Bambi Mod
I don't think it's any special lighting--just red colored. Red light is less visible to the human eye. Put a red lens cover on a flashlight and it puts out much less light yet is still visible up close.
Old Oct 19, 2009 | 11:21 PM
bankrpt's Avatar
yeah i dont have fogs im looking for a bumper though
Old Oct 19, 2009 | 11:34 PM
AAK625's Avatar
So, all I need is some red bulbs?
Old Oct 19, 2009 | 11:36 PM
mblouir's Avatar
I'd think so, although it may get old after a while if you're trying to read something inside the cab at night. May be a strain on your eyes. Would be unique, though, and I'm actually curious to how it would turn out. If you do it post up pics!
Old Oct 19, 2009 | 11:38 PM
bankrpt's Avatar
i replaced all my interior bulbs for green leds got old after a while lol
Old Oct 20, 2009 | 12:02 AM
AAK625's Avatar
I wish I had the know-how to make a dual system. Red lights for turning the ignition off or unlocking the vehicle and then the regular lights for seeing stuff.
Old Oct 20, 2009 | 02:04 AM
02SC4x4's Avatar
I'd also like to know how to stop that AND the interior lights from coming on.
to turn off your interior lights and keep them off turn your dimmer switch all the way down to dim, and then keep going down more til you here it click.
the dimmer switch has 3 positions;
all the way up - interior lights on, dash illumination 100%
in the middle - interior lights on auto (door open/truck unlock they will come on), dash illumination what u set it to
all the way down - interior lights will never come on regardless of doors open/truck unlock, dash illumination at its lowest
Old Oct 20, 2009 | 05:50 PM
Just change the dome light only, and leave the map lights white
Old Oct 20, 2009 | 05:54 PM
bankrpt's Avatar
Cause our front map lights come on with the rear dome light
Old Oct 20, 2009 | 05:58 PM
so bypass the map lights when in the dome position, and have map lights only on when selected.
bankrpt you should update your profile, since it says you still have a 1993 F150
Old Oct 20, 2009 | 06:35 PM
bankrpt's Avatar
I do still have a 93 that's my show truck
Old Oct 20, 2009 | 06:37 PM
bankrpt's Avatar
Look at my profiles pics bud
Old Oct 21, 2009 | 12:17 AM
truckin150's Avatar
How do u disable the seatbelt chimes for the passager seat, and can u do the driver seat two or just the passanger
Old Oct 21, 2009 | 02:47 PM
mblouir's Avatar
You do both independently. I've got some errands to run but I'll post up how later if no one answers by then.
