Problem since body lift?
Old Oct 13, 2009 | 10:05 PM
klink82's Avatar
Ever since I got my body lift put on my 06 xlt drive on my gear selector is just before the actual D on the selector. So when it is on D it is actually 2nd. I have read something about a cable extension, but I didn't have one so I need to know what to do?
Old Oct 13, 2009 | 10:08 PM
wandell's Avatar
I'm not familar with the 04-08's but on my truck there is dial adjustment under the dash to adjust the gear selector.
Old Oct 13, 2009 | 10:23 PM
bjp207's Avatar
There is one on the 04-08's too
Old Oct 13, 2009 | 10:24 PM
Justin_w32's Avatar
did you install it yourself?
Old Oct 13, 2009 | 11:25 PM
klink82's Avatar
No I was to busy at work. How and where do I adjust it? Never had to do this on my chevy trucks
Old Oct 15, 2009 | 12:05 AM
Justin_w32's Avatar
Well if its a reputable shop then they should have given you some kind of warranty right? If so take that ho back and get em to fix it. They should fix it thats just good business. That is unless you had your buddies install it in someones back yard, if thats the case I would take it to a 4x4 shop and get them to look it over anyway. Good luck.
Old Oct 15, 2009 | 07:42 AM
klink82's Avatar
I fixed it myself. All it took was a couple turns on the adjustment wheel under the bottom panel. Easy fix 5 minutes
Old Oct 15, 2009 | 09:08 PM
edgespeeder06's Avatar
can anyone explain it to me where this is exactly...I have the same exact issue and the reason why my truck wont start sometimes because its not directly on park.....I appreciate it...pics would help too.
Old Oct 15, 2009 | 09:13 PM
found it....should look like this
