Aerokroil ?? 5.4 Plug Change TSB
Old Oct 8, 2009 | 11:50 AM
duckduke's Avatar
I've been reading here for month and I know that the original TSB called for Aerokroil.
The newer or most recent TSB (I think) now suggests using Motorcraft Carb Cleaner.
I just did a search and alot of reading here and found where others have used:
1) WD-40
2) Gunk Penetrating products
3) and a few others
Does it really make much difference which??
My son just stopped by a local Ford dealer and called to ask what the stuff was I needed..........I told him Motorcraft Carb Cleaner.
He got with the parts guy who informed him that the current TSB specified Aerokroil and that is what he sold my son.
Unless there's an issue.............looks like I'll be going with Aerokroil.
Thanks for any info!
Old Oct 8, 2009 | 12:34 PM
Dstang's Avatar
I haven't used aerokroil but have read on here how good it is. I used the motorcraft tune up stuff and it worked really good as far eating away at the carbon. I would just go down to your local dealer and get a can, its only like 5 buck for a pretty good size can.
Old Oct 8, 2009 | 12:40 PM
The newest TSB states Motorcraft Carb Cleaner that's what I'd use. There's a reason they switched away from Aerokroil.
Old Oct 9, 2009 | 05:25 PM
No-Tyme's Avatar
carb cleaner
When I did my plugs on my 5.4 the thrid TSB was out saying to use a carb cleaner... I used one from Napa, and all went well.
Old Oct 9, 2009 | 05:47 PM
Big Slick's Avatar
did they state why?
Old Oct 9, 2009 | 05:49 PM
The carb cleaner works better at breaking down the deposits on the plug than the aerokroil.
Old Oct 9, 2009 | 07:34 PM
svt2205's Avatar
I used the Kroil penetrating solvent and broke 3 plugs. Best results seem to go with Motorcrafts Carb Tune Up Solvent.
Old Oct 9, 2009 | 09:07 PM
Quintin's Avatar
I use whatever I can get my hands on at the time. PM-12, WD40, PB Blaster, Kroil, generic carb cleaner, brake clean, just anything to get in there and help loosen deposits on the plugs.
Old Oct 10, 2009 | 12:28 PM
No-Tyme's Avatar
Originally Posted by Big Slick
did they state why?
My understanding is the problem is the carbon build up on the long extended part of the plug. Carb cleaner seems like it would work better and loosening this and the Aerokroil would be good for the threads of the plug itself. JMO...
Old Oct 10, 2009 | 02:29 PM
57 rag's Avatar
With the carb cleaner, you do it with the engine cold right? I read it on one of the searches.
Old Oct 10, 2009 | 08:12 PM
No-Tyme's Avatar
Yes! I did the cold soak (they highly recommend cold) after you make sure it is a clean as you can get it with air, fill the well up to the jam nut with carb cleaner.
Old Oct 10, 2009 | 08:37 PM
Paralyzer's Avatar
honestly it doesnt matter what you use....the chances of them breaking stays the same i dont care what the tsb says...
Old Oct 10, 2009 | 09:22 PM
Quality of gas and driving style adds or lessens the chances of the plugs breaking also.
Using el cheap-o gas will leave much more deposits on the plugs than a gas with good detergent additives.
