my truck has autostart
Old Oct 6, 2009 | 09:53 PM
greencrew's Avatar
Last week when a friend had his test equipment connected to my battery he asked me to turn the engine over but not start it. I found that to be impossible. Not because it started to quickly, but because once I turned the key the starter stayed engaged until the engine started, which was well past the length of time I held the key turned. It was if the truck is programmed to start and release the starter when it starts, and pays no attention to how long you hold the key, or the switch has a minimum contact time. Is that the case?
Old Oct 6, 2009 | 10:01 PM
shorse's Avatar
yea, my dads 08 f250 and my moms 09 explorer both do this... i like it
all u gotta do is blip the key, and it will start... helps for when its cold vs warm taking different ammount of time the key needs to be held on older vehicles..
Old Oct 6, 2009 | 10:45 PM
08stx4x4's Avatar
My 08 F150 does this. It's always done it since I bought it and I would guess it's normal. Definitely makes it easier to start the truck when it takes a while longer to start.
Old Oct 7, 2009 | 09:00 AM
HCBPH's Avatar
Starting
Never seen that so this is just a thought. If you don't like that, see if there's something in the manual on how to disable that function.
Old Oct 7, 2009 | 09:21 AM
08FX4's Avatar
My '08 FX4, my brother's '07 Lariat, and my Dad's '09 King Ranch all do this as well. It's a pretty neat little feature.
Old Oct 7, 2009 | 01:37 PM
Ballin STX's Avatar
my 2005 f150 didnt have this feature but my 2008 does.. good feature imo.
Old Oct 7, 2009 | 01:51 PM
4.6 Punisher's Avatar
Mine doesn't have it, but I know of a trick to just crank it but not start it. Hold the gas pedal down all the way while turning the key. I've heard this works, but never tried it.
Old Oct 7, 2009 | 02:24 PM
mdhawkin's Avatar
My 08 does it as well, I like it. However when I try to start my girlfriends Solara it does not got so well the first time, funny how you just start expecting things to do as you are used to.
Old Oct 7, 2009 | 02:52 PM
yetti96's Avatar
I don't see the point in it but then again I don't have it. As a matter of fact, I only put my key in and twist to the on position anyways. Remote start FTW
Old Oct 7, 2009 | 06:45 PM
John_Deere_Man's Avatar
My 03 F150 would do this, but my 07 will not, it just starts and revs up. tried it several times trying to play with peoples minds on haloween.
Old Oct 7, 2009 | 06:55 PM
sampson01's Avatar
its a cool feature but are we really getting that lazy??? lol
Old Oct 7, 2009 | 09:49 PM
jdruzik's Avatar
I love this feature... It will probably lengthen the life of the starter...
Old Oct 8, 2009 | 09:05 AM
sampson01's Avatar
starter is still working the same amount pretty much
Old Oct 8, 2009 | 09:50 PM
cstanek's Avatar
Holding the accelerator all the way to the floor actually shuts off the fuel supply.
Old Oct 9, 2009 | 12:23 AM
stangdude's Avatar
The pedal trick works on most distributor-less vehicles, but I've noticed a lot of the newer ones do like one of the above posters said. My dad's 05 starts and revs up. My 02 cranked and didn't start. Might be a feature manufacturers have moved away from. Used to be a nice way to test starters.
