headrest monitors..
headrest monitors..
i have just installed 2 9.2" audiovox monitors and a pyle dvd player. for some reason when everything is on, there is like a slight static on the monitors while the dvd is playing. almost like vertical lines scrolling across the screen. ( 90%clear, 10% static) now i wired the 2 monitors and dvd player using a a relay and inline fuse. everything was tighly crimped and taped so i know its not a loose connection. so last night, just for curiousity, i got my dvd player from my house, pluged it in and hooked up the rca's directly to the monitors and it played perfect. so i narrowed it down to the dvd player. thinking its a power issue but cant figure out why. has anybody had this problem before or could help me out??
thanks, anthony
thanks, anthony
i did some more troubleshooting and narrowed it down to my battery. i thinks theres noise interference traveling thru my batt and into the feed for the dvd player. because i hooked the dvd player up to a 12v battery charger and it played real nice.
umm not likey. Batteries don't induce noise. Bad grounds, bad rca's, faulty ignition wires, cheap components, and shotty installation create noise. Run a better ground and get quality RCA cables.
When you have the noise is the truck running or is it off? I work nights so it will be a while before i can reply again, bed beckons me.
The static on the screens happens when the truck
Is Both on or off. I know it has
Nothing to do with the RCA, because I tried a DVD player from my house and it played good. And when I wired the car DVD player directly to the batt it still did it. I'm thinking that something else that I have installed is backfeeding some sort of interference . So when I get home I'm gonna start with the process of elimination- disconnecting each electronic accessory I have connected to the
Battery and see if it Gets better.
