Engine light on
Old Sep 24, 2009 | 02:36 PM
anaheim's Avatar
Engine light on
Hi all,
Question: My engine light came on as i was driving home from work yesterday.
The book says it has something to do with the emissions system?
I have recently replaced the fuel and air filter.
Is this something i need to take in to the dealer?
Thanks~
Old Sep 24, 2009 | 03:01 PM
huddles93's Avatar
Have a local auto parts store run a diagnostic on it and get the code. Mine did that a while back with an emissions light and it was just the cam sensors, under $10 each at autozone and less than 5 min. to install. There are two of them, one on each head in the front of the engine with one small bolt and a wire connector on each one.
It could also be the MAF sensor needs cleaned if you are using an oiled filter.
Hope this helps.
Old Sep 24, 2009 | 08:33 PM
Grubrunner's Avatar
Originally Posted by anaheim
Hi all,
Thanks~
If the part in bold is all you've done recently then that shouldn't throw a code.
Try disconnecting the battery, leave it disconnected for about 1-3mins, reconnect it and see if the code is visible. If it's still there, follows huddles93's suggestion.
Post the outcome [exact code and part] for anyone else that may encounter a similar issue down the track.
Good luck.
PS: An oiled AM filter never thru a code on my truck when I had one for several months before my S&B CAI system.
Old Sep 25, 2009 | 10:47 AM
anaheim's Avatar
Good luck.
I do have a Fram Air Hog, but as you said have never had an issue with it.
I will have an Autozone check out the code this weekend and will post.
Old Sep 27, 2009 | 02:23 PM
anaheim's Avatar
Well, i didn't take it to Autozone, but I disconnected the battery and cleaned the MAF, engine light is now off. Now will see if it stays off.
Old Sep 27, 2009 | 08:49 PM
BlueOvalFitter's Avatar
Exclamation
When I changed my air filter once I got a CEL.Found out it was the rubber grommet for the MAF sensor wires that was not put back in the hole on the filter housing.
