Yet another 04 plug question
When I did the driver's side plugs I just worked around things, there is more room on that side. On the passenger's side, you need to carefully remove the PCM and the bracket that holds it to the firewall. It is not necessary to unplug any of the cables, but you may need to tie the PCM up out of the way while you are working. This makes it much easier to do the back 2 plugs on that side.
