Enginge went to idle and would not go
Ok, so I'm driving home with the cruise on and after I had to hit the brakes, the engine went to idle and would not rev up and go. The check engine light went on and I coasted to a stop.
The engine was idling rough and would not rev up. I shut the engine off and it spun over several times before it started back up. The check engine light did not come on and it went into gear and ran like it did before.
The truck has 102,000 miles on it and has had the transmission serviced earlier this year and I've probably put 10,00 on it since the service with no problems.
Anyone have any suggestions as to what would cause this? It seems ok now but I'm really not sure.
The truck is a 2005 F-150 Screw 4X2 5.4 auto
Sorry, I hit the 0 too many times. It has 102,000 on it. The engine runs good, it just seemed like it maybe the throttle position sensor or something went bad.
Just need any suggestions as to what it actually might be.
you should just be thankful your truck has gone over a million miles already and is still running, I wouldnt complaing so much
jk... but ive had this happen before.. I have a xcal2 with custom tunes so i bumped the idle up but i still lose power when i put into park, i will bump the idle up to 800, its at 700 now.
replace fuel filter, run a cleaner, spark plugs if you havent changed them, o2 sensors... use good quality gas
mine did something similar last week. i was driving and about to get on the interstate so i punched it and no throttle response. the check engine light came on so i pulled over and checked the codes. there was about 5 of them and all were throttle related so i got out and checked the throttle body and the plug on the tps was loose and wouldnt stay on tight. i just pushed it in and wrapped it with tape to hold it in there for now lol.
The potentiometer is the "rheostat" that is on the foot pedal in the truck. it simply sends an ever increasing signal to the PCM which then sends ever increasing power to the servo motor on the throttle body as you step down on the throttle. The only servo motor is on the throttle body. Just a "rheostat" or potentiometer inside the truck. I'm not sure, but on my wife's car, the throttle position sensor is part of the servo motor assy. It used to be separate on the Fords of a few years ago, but i think they found it could easily be incorporated in the servo assy.
