Is there such thing as a 2-piece rotor/hub replacement?
#77
Was gonna buy this setup as seen in this Centric TSB off eBay but my Groupon 15 dollar eBay certificate isn't working right now.
http://www.centricparts.com/files/F150%20Rotor_Hub%20Retrofit.pdf
Hub and Rotor (separate pieces) updated number from Centric: 120.65128
Cheapest I found was on eBay for 147.33 per front side. So a total of 294.66 shipped.
Anyone find this cheaper than eBay?
#83
I just called their sales line. They were very nice and they guy i spoke to knew of the kit. Should be here Friday...
888-712-6623 - they are on the west coast.
http://www.r1concepts.com/blog/2004-...-brake-rotors/
#84
#86
(Quoted to show images of the kit)
Just did this kit, Centric 120.65128 which is a hub, rotor, and nut. Simple R/R job and highly recommended.
http://www.centricparts.com/files/F1...20Retrofit.pdf
#87
Centric makes a conversion from solid to the two piece hub
You might try Frugal Mechanic for purchase
#88
So just wanna make sure I'm getting the right stuff before I place an order and end up not having everything I need...
So if I order centric hubs #12465902 then get some 4x4 front rotors and pads and the retaining nuts I will be good to go? just want to make sure those hubs also include the bearings?
Gonna get hubs & nuts from rockauto then summitracing for the rotors and pads
Thanks for the help
Thanks for the help
#89
MY TRUCK IS LIFTED WITH 35s...Its a 05 2wd and I have been replacing rotors/bearings it seems every 6 months,my wheel offset puts alot of strain as well...Anyone else with a lifted truck running this kit that can chime in?Are these better quality bearings?Can we replace bearings only,and not the whole hub assembly?
#90
K,just got off the phone with Centric and the bearings are not replaceable,the hub needs to be replaced so I might be in the same neverending boat with bearing failure? Although he did say it is a better and stronger bearing design!Hopefully with this design,there is less strain on the bearings!He also stated most peoples biggest mistake is not torquing the nut down properly @ 295Lbs...Overtightening will cause premature failure!!! Once again,part number for entire kits-
120.65128 standard rotors!
120.65128SL.SR slotted!
124.65902 hub/bearing assy!
Getting ready to order now!Gawd I hope these last a while!!!
