Clearance Lights on TT Mirrors
Old Sep 6, 2009 | 11:58 AM
labman1014's Avatar
Clearance Lights on TT Mirrors/ Now with How To p.3
i have been doing alot of research on adding clearance lights to my TT mirrors. i have some close calls with ppl getting a lil too close and i like the look also. i looked at the F250 lights, but that are too big to fit inbetween the arms. also, the mirrors dont come all the way apart, so it would be a PITA to get them in.
i found these: http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
and after further research in the disassembly of the mirror, i can remove the skull cap and make a cutout of the light and mount it to the mirror and then add the skull cap back on, so it will look flush with the mirror.
i really wanted to add front turn signals also, but i dont think there is room for 2 lights and i dont know how to wire the one light to do both options.
i also plan on adding the roof clearance lights also following Tylus's write up. i think this will really set off my truck and make it the mean towing machine that it is!!
what do you think???
Old Sep 6, 2009 | 12:25 PM
bankrpt's Avatar
if i was you i would do something to this nature you could get 5 or 6 of them drill a small hole and insert them in they would be almost flush and look coolhttp://www.plasmaled.com/5mm8mmled.htm
Old Sep 6, 2009 | 01:16 PM
labman1014's Avatar
i kinda thought about that too. i remember someone putting them in theirs at the bottom of their mirros a year or so ago. but i kinda want some type of lense cover also so it can be easily seen in the day time also. but it is a thought. thanks!!!
Old Sep 6, 2009 | 01:55 PM
Impact9's Avatar
I think those were the turn signal lights someone modded with LED strip lights. There was also a post a few months back where someone added puddle lights to their stock mirrors.
Old Sep 6, 2009 | 04:45 PM
labman1014's Avatar
any links??
Old Sep 6, 2009 | 05:05 PM
Impact9's Avatar
Here's the one link I was thinking about. I think it covers it all:
https://www.f150online.com/forums/20...ver-built.html
Old Sep 6, 2009 | 05:36 PM
labman1014's Avatar
yea, thats the one i found. wish his pics still worked!!!
Old Sep 6, 2009 | 05:51 PM
Tylus's Avatar
https://www.f150online.com/forums/20...ls-mirror.html
http://www.oznium.com
awesome place to buy pre-wired LED's. I started this mod on my FX4, but traded her in before finishing it. Not that hard to do actually. I had everything wired in and it all worked. Last thing to do was the actual drill work.
Josiah did it also, but the pictures are dead. Maybe PM Josiah and see if he can upload some pics
Old Sep 6, 2009 | 06:42 PM
labman1014's Avatar
ok, i see where i can possibly go with these. i can wire 3 as a clearance light and 3 as a turn signal in 2 rows up and down and each row will be each, if you know what i mean. but i want some type of lens over them. i would love the F250 look, but will settle for some type that looks good.
see where im going?
Old Sep 6, 2009 | 06:57 PM
Impact9's Avatar
Well if you can cut and heat form some thin lexan you might get what you want. I've got a spare set of OEM heated mirrors in the garage I planned on doing just the signals on. But if you make this happen that would be friggen awesome.
Old Sep 6, 2009 | 08:19 PM
labman1014's Avatar
do they make colored lexan? would be awesome and doable if i can find some amber lexan!!!
the only problem i see is on the TT mirrors, you cant take the complete back off like you can the plain mirrors. so mounting the leds from the back will be near impossible, unless i can remove the power mirror motor......
Old Sep 7, 2009 | 08:59 AM
Impact9's Avatar
US Plastics sells it here
Old Sep 7, 2009 | 09:18 AM
bankrpt's Avatar
Do you still have your mirrors that you replaced the tt mirrors for?
Old Sep 7, 2009 | 09:52 AM
labman1014's Avatar
no sorry, i added these over 2 years ago and sold them then!!
Old Sep 7, 2009 | 09:53 AM
bankrpt's Avatar
O ok thanks
