stolen gas
Old Sep 4, 2009 | 11:19 PM
Cdn-Redneck's Avatar
Angry stolen gas
I had my gas tank punctured last night. I found out this is how they are stealing gas. Punch a hole in the tank and let the gas run into a jerry can. Bought a used tank and put it in tonight, should have just done insurance claim. It left me stuck on a boat launch. I thought I couldn't pick up the fuel because of the angle, but after adding gas we heard it running on the ground. Just venting my anger.
Old Sep 4, 2009 | 11:29 PM
nuclearthreat54's Avatar
wow thats f'd up. You left your truck on the ramp and then some one came alone in the day and did that?
Old Sep 4, 2009 | 11:30 PM
che22879's Avatar
sorry to hear that!
Old Sep 4, 2009 | 11:33 PM
abervintageman4's Avatar
wow thats bull****! some people these days man its rediculous
Old Sep 5, 2009 | 12:15 AM
ya there was nobody else parked there at the time so it was easy pickins. i parked the truck around 3:30 and came back around 8:00. Normally there are about 10 -20 other trucks there. The wrecker said they have been selling quite a few tanks.
Old Sep 5, 2009 | 12:19 AM
rednoved's Avatar
That sucks. Probably the wrecking company. Take your gas, sell it back to you. When you find out tank has a hole, they offer a pricey tow. Perfect plan.
Old Sep 5, 2009 | 12:21 AM
bigchief2472000's Avatar
dang that sucks. i had to drop my tank to change out the fuel pump a while back and it was a pain in the a** trying to get a syphon hose in the tank to drain it. im sure thats why they just jabbed a hole in it.
Old Sep 5, 2009 | 12:51 AM
Impact9's Avatar
Pretty ballsy. If that was a problem around here I'd be mounting a steel plate under the tank. Been a few times I thought about making a shield for the filler line that's exposed in the wheel well.
Old Sep 5, 2009 | 10:53 AM
4.6 Punisher's Avatar
Armor plate the tank, problem solved.
Old Sep 5, 2009 | 01:05 PM
bbarber275's Avatar
Cordless drill and a sharp drill takes seconds to get a hole in the tank.I have done this alot when I drain the gas from tanks before I take a car to the scrap yard.
Old Sep 5, 2009 | 07:07 PM
06yz250f's Avatar
what about a tiny spark blowing up the tank during drilling?
Old Sep 5, 2009 | 07:27 PM
blackjack8900's Avatar
Gas tank is made out of composite plastic.
I would be pissed if that happen to me.
Old Sep 6, 2009 | 12:17 AM
Maxout05's Avatar
I think the show mythbusters debunked that along time ago!!
Old Sep 6, 2009 | 12:34 AM
06yz250f's Avatar
i was just curious since apparently cell phones are unsafe at a pump, i cant see drilling into a tank being any safer.
Old Sep 6, 2009 | 03:54 AM
code58's Avatar
Unless they make plastic tanks that spark, I don't think you'll have to worry too much about it. You do realize that liquid gasoline won't explode or burn, it's only the fumes mixed with the right amount of air that burns. A tanker truck burns furiously when it gets going because as it gets hotter, it's generating more and more fumes off the liquid. When they use foam to put out a fuel fire, all they're doing is cutting off the oxygen that is necessary for combustion.
