Factory Navigation
Old Aug 30, 2009 | 08:24 PM
Menghi08Lt's Avatar
Factory Navigation
Found an OEM factory nav/cd player that apparently goes right into the truck, was pulled out of an '08. Does anyone know if this is plug-play and is compatible with Sirius and my aux plug? Truck's also an '08, lariat, and I have the steering wheel controls.
Old Aug 30, 2009 | 08:27 PM
City of Champs's Avatar
i put one in my '05 and it can be plug and play. for your '08 it might be 100% set up for it. but my '05 was not. I had a install the vss wires to the cluster and the steering wheel controls. It wasnt even an option till 2007.
Do you already have a Sirius module? if so does it have a "T" for termination on the part # sticker?
Old Aug 30, 2009 | 08:29 PM
Menghi08Lt's Avatar
It's already set-up for Sirius, so yes it does have the Module, and I have never had the bezel off so I don't know any of the numbers behind there. All I know that I have now is the 6-CD MP3 changer with the Aux jack on the dash, Sirius, and the steering wheel buttons.
Old Aug 30, 2009 | 08:33 PM
I would venture to say its plug and play. if its not, its an easy fix.
Old Aug 30, 2009 | 08:41 PM
when you start your install or open the dash to venture around, could you do me a favor?
look at your Sirius tuner, it should look like this.....
http://cgi.ebay.com/ebaymotors/ws/eB...m=300341515744
if it does in fact have the "T" on it. can you measure the resistance btw pins 15, 16. They are the bottom left if the button is on the top. (long story why)
Old Aug 30, 2009 | 08:50 PM
Menghi08Lt's Avatar
I'll probably wrestle to get the bezel off tomorrow. Seems like a son of a B... lol. I just went outside and tried it, and gave up out of fear of breaking it. I should be able to use the same one, correct?
Thanks in advance
EDIT: http://cgi.ebay.com/ebaymotors/FORD-...fAudioQ5fVideo
That's the one in question. has the pn right in the add.
Old Aug 30, 2009 | 10:54 PM
Menghi08Lt's Avatar
You have a PM.
