Handle covers PTM
Old Feb 27, 2010 | 01:41 AM
  #46
808TritonXL's Avatar
The overlays sounds like a plan..
here is a full view of my truck...where can I get the overlays from?
Old Feb 27, 2010 | 05:38 AM
  #47
ELVATO's Avatar
Patriotdecals.com
Old Feb 27, 2010 | 07:05 AM
  #48
XPerties's Avatar
Anyone have any clue what the easiest way to get the covers off first them spray them and reapply? Ive had them on for well over a year and like to do the PTM as shown in this thread.
Old Feb 28, 2010 | 02:51 AM
  #49
Originally Posted by ELVATO
It's white, you probably can't tell. Maybe wait a little to let the paint dry up, then hit it with a little polish.
Also, you should probably get an overlay for the Ford emblem to better go with the handles. Maybe white and chrome? Not sure what the rest of your truck looks like.
white and chrome...that would be white back with chrome letters? I think that would look really cool...
Old Feb 28, 2010 | 03:11 AM
  #50
Okay...I just ordered some chrome inlays..
I was thinking bout making the back black, but I haven't seen any white background...so I'll go with the suggestion by ELVATO....
1-2weeks before I get it...I think I'll hit the white next weekend. I gotta buy more paint..lol!!
Old Feb 28, 2010 | 04:44 PM
  #51
TI_F150BLKSCREW's Avatar
I tried several adhesive removers to get my old ones off but it's not going to happen. The best thing to do is remove them while taking your time so you don't scar up the handles underneath (1 poster said he broke his 2 of the plastic handles while taking the old covers off).
You can get a new set shipped for 30 off ebay. Buy a roll of the 3m auto heavy duty emblem tape from your auto parts store and apply more tape as the tape they put on them isn't enough for long term apps.
Old Feb 28, 2010 | 04:57 PM
  #52
I went the same route as several others did that posted on here - 600 & 1500 grit sandpapers, adhesion promoter, duplicolor paint & clear and extra 3m tape.
The supplies:
Sanded down to where they looked like brushed aluminum:
Shot 5 coats of base coat and later came back with 4 coats of clear:
Up-Close shot of the end result:
Final look of the handles installed on the truck - all in all - very pleased with the outcome - took a bit longer than I thought they may but I took my time shooting coats and letting them sit overnight before colorsanding them down before shooting the clear.
Old Mar 1, 2010 | 11:03 AM
  #53
ab46501's Avatar
Looks great! Nice job with the black is almost impossible to tell it is a cover.
Old Mar 1, 2010 | 11:06 AM
  #54
ab46501's Avatar
3M makes an adhesive remover. I have used it on molding tape before and it works OK. You really have to hit it with several coats and let it sit for 30 minutes or so for it to have time to work. That and hot air from a hair dryer or heat gun is my best suggestion. If you use the heat gun be careful not to melt anything though!
Old Mar 2, 2010 | 10:28 PM
  #55
TI...that is a nice job you did there..
can't even tell there is a cover...
My next project is the PTM grille...that one..I'm taking my time...lol!!!!
Old Mar 12, 2010 | 08:46 AM
  #56
Lizardking's Avatar
Heres a tip I learned from a bodyshop. Ford uses different color primers under different color paints. On a Cardinal Red or a Oxford White the primer is white. If you did a PTM and the color is slightly off its probley because you didnt use primer or used a gray or red primer.
When you get ready to PTM call a bodyshop or automotive paint store and find out what color primer to use. On my red Mustang I had to get the primer in a spray can from an automotive paint store. $10 but it color matched perfect.
Once you get the basecoat on, I take the part to a bodyshop and have them clearcoat it. It lasts much longer than spraycan clear, and Ive never been charged more than $25.
On my XL I have to use the keyhole and the clear holds up much better.
Old Mar 12, 2010 | 01:58 PM
  #57
Mr. eXtreme's Avatar
Anyone doen this and also paint the actual handle part?
I'm looking to do mine. But want it all silver to match.
EDIT: Or do this and leave the handle it self black?
Old Mar 12, 2010 | 02:13 PM
  #58
bheemsoth's Avatar
When you guys apply the extra 3m tape, do you apply it on top of what comes on the handles? Or, do you remove what is there, and re-apply?
My handles should arrive today, so I at least have a project for this cold rainy weekend.
Old Mar 12, 2010 | 02:15 PM
  #59
shibby2's Avatar
I'm doing this right now, all silver, handles and buckets. Looks just like a factory paint job, if you put the time and effort into it.
I'm **** about it, so it's taking me a long time. This is what I do..
1) 2 coats of adhesion promotor (if paintable black -- if chrome, sand to dull first).
2) 4 coats of color (then wetsand with 2000 grit until the paint texture is smooth, no 'orange peel'), let dry 24 hours.
3) hand-buff with a simple car wax until it shines like a mirror
4) 2 coats of clear when you're happy with the paint finish.
5) Hand-buff again with wax, but wait a couple days after clear coat is dried.
I only finished one handle/bucket so far, but it looks like a factory paint job. The key is to get the paint flat with the wetsanding/buffing. Use a light very close to your work so you can see the texture of the finish. You should be able to see the reflection of the light bulb itself in the finish clearly...if it gets distorted, the paint is still bumpy and needs more wetsanding/buffing. Be careful around the corners and edges, as the paint will come off a lot faster/easier there.
Old Mar 12, 2010 | 02:21 PM
  #60
I only finished one handle/bucket so far, but it looks like a factory paint job. The key is to get the paint flat with the wetsanding/buffing. Use a light very close to your work so you can see the texture of the finish. You should be able to see the light bulb itself in the finish clearly...if it gets distorted, the paint is still bumpy and needs more wetsanding/buffing. Be careful around the corners and edges, as the paint will come off a lot faster/easier there.
Won't the waxing before you clear hinder the way the paint will adhere?
Can't wait to see the finished pics!!
