code: P1233
Old Aug 11, 2009 | 02:52 AM
jetfixer1's Avatar
code: P1233
i just recently got the DTC P1233 on my Edge Evolution. I know its in ref to the fuel pump driver offline. the truck starts fine, and it hasnt died on me, but i was wondering if anyone w/ an 04 or up f150 has encountered this code and what they did to fix it. truck doesnt seem to idle as smooth. i remember recently reading something about someone replacing an electronic module mounted on the crossmember fwd of the spare tire.
Old Mar 25, 2010 | 07:29 PM
derik taylor's Avatar
I just got a edge evolution also for my '04 F150. I too am getting the DTC P1233 relating to the Fuel Pump Driver "off-line". I haven't experienced any troubles with my truck, or lets say any that I was aware of. Would this trouble code be something that I have had for a while, or would the edge evolution be causing the problem. Also, if this code something to even worry about?
Thanks!!
Old Mar 25, 2010 | 11:12 PM
BuRDeN04FX4's Avatar
ive got it showing up on my 04 aswell with the evo but its not the evo ive had te evo for about 2 years and it just came up about 3 weeks ago but my truck needs a serious tune up i also remember seeing something about someone else replacing it because of corrosion
Old Mar 26, 2010 | 06:57 AM
10-4 thanks. I guess I'll be keeping an eye out on it, and thinking about replacing it soon.
Old Mar 28, 2010 | 08:29 PM
Anyone ever simply reset ther IRS or fuel shutoff switch to clear the code p1233? I was wondering if that would be better to try before replacing the fuel pump driver module. If so, I am assuming the switch is located besides the fuse box inside passenger kick panel. Is it as simple as pressing the button, or is there more steps to it. I don't want to screw anything up!
Thanks!!
Old Mar 28, 2010 | 08:40 PM
bjp207's Avatar
It won't fix it,if your getting the fpdm code, it needs replaced immediately
02SC4x4's Avatar
this would be the thread you are looking for.
https://www.f150online.com/forums/ar...placement.html
Old Mar 28, 2010 | 08:44 PM
MGDfan's Avatar
Derik - if that was the case (tripped) do you think yer truck would be running at all?
Replace the FPDM ASAP.
Y'all need to learn to use the search function:
Here are the threads: https://www.f150online.com/forums/se...archid=3523141
MGD v5.0
Old Mar 28, 2010 | 10:15 PM
sorry about that....I have already ordered a FPDM from ebay and it is on the way to me. I just have searched on here before and found someone had just resetted the IFS and it worked. I guess it does make sense...if the IFS was tripped, the truck wouldn't run...
Do I need to do anything besides "plug and play" the new FPDM? For instance, disconnect the battery during the swap?? I don't think the procedure listed addressed that.
Sorry for all questions! I am not a usual "do-it-yourselfer"....
Old Mar 29, 2010 | 11:13 AM
MGD, you can't link to your search results like that, it's a vBulletin limitation.
Old Mar 29, 2010 | 11:19 AM
MGDfan's Avatar
Aww crap - Shotgunz does it
That's unfortunate - would be real handy ...
thanks
