Who has the highest mileage 5.4 3V?
Old Aug 11, 2009 | 01:43 AM
  #46
Halverso_99's Avatar
For the 97-03's I seen a guy who had over a million miles on his 97.
Old Aug 11, 2009 | 02:03 AM
  #47
AAK625's Avatar
78k on my 04 FX4 SCREW.
Old Aug 11, 2009 | 12:28 PM
  #48
Mr. eXtreme's Avatar
I have 54, and change on my 2006 bought new in Feb of 07...
Old Aug 11, 2009 | 12:36 PM
  #49
89,900 on my 2005. Should hit 90,000 tomorrow. Running great!
Old Aug 11, 2009 | 12:45 PM
  #50
LincolnMarkLT20's Avatar
I bought my 06 truck last year 34,000 I drove it from IN. to CA. no problems truck is very strong, now I have 51,000 miles, the only problem I had was the IWE solenoid but replace part and have not had a problem since.
Old Aug 11, 2009 | 01:45 PM
  #51
Trogdors4x4's Avatar
83k on mine. Original Plugs. Only thing I did was replace the passenger actuator and IWE solenoid. I still have a vaccuum leak somewhere, however.
Old Aug 11, 2009 | 09:35 PM
  #52
digit4lcowboy's Avatar
85k on my 04. The only thing I've had to do under the hood is replace the battery and I had some carbon build up this past winter that was making it lag on take off. The dealer wanted about $250 to clean it up and I got it cleaned at my local mechanic for $25. I have had to replace my front passenger 4wd actuater twice. Both times they said I got water in it. Funny thing is the I hadn't been in water up to the hubs between the first and second replacement. Other than that it has been a good truck.
Old Aug 13, 2009 | 03:50 PM
  #53
BDLZ's Avatar
72k on my 04. Dealer I bought it from was troubleshooting ticking noise and had to replace #4 rocker arm and lifters, camshaft, left side lifters and camshaft phasers. I don't know the history of the truck before the repair, but runs great now.
Old Aug 13, 2009 | 04:38 PM
  #54
YOMAN's Avatar
just rolling over 60K with few TSB issues and replaced spark plugs with no problem.
I am planning to check the spark plugs, and clean it in next 10K milages.
04 FX4 Screw
YOMAN!
Old Aug 13, 2009 | 05:07 PM
  #55
code58's Avatar
Originally Posted by RoushF150
Perhaps you can have a minimum, like 150K miles. I'm guessing some have gone well over this on their work mules.
Excellent idea- would tend to eliminate PW's.
Old Aug 13, 2009 | 11:24 PM
  #56
Drdudsads
Guest
Posts: n/a
Two years old and 34K miles.
Old Aug 14, 2009 | 10:44 AM
  #57
JasonFX4's Avatar
76k on my 07
Old Aug 17, 2009 | 10:04 AM
  #58
JGP2009's Avatar
ive got 124000 on my 2005 runs like hell still!
Old Aug 17, 2009 | 10:18 AM
  #59
FATHERFORD's Avatar
70k+ on a 12lb boosted 5.4 3v...
Old Aug 17, 2009 | 11:51 AM
  #60
PhqChevys's Avatar
Originally Posted by MILariat
I'm running strong as can be with 29k on my 07' 5.4 lariat! Hows are these transmissions holding up? I'm debating whether to change the fluid at 30k or not.
Also a '07 5.4, except XLT and 4x4... 34k and running strong! Changed my AFT at 30k, used Royal Purple, highly recommend, far smoother shifting and cooler trans temps. Did a full flush and new filter to completely replace AFT.
