BMW moon lighting in F150 ?
Old Aug 4, 2009 | 06:14 PM
Mr. eXtreme's Avatar
So I have been thinking about mounting a couple LED's in my overhead map light bezel... TO get the effect of moon lighting like that in a BMW...
Anyone done this or have any ideas as to how it can be done?? NEATLY...
My thought was to drill a reverse counter sunk hole in the back of the bezel for the LED's to sit in then a smaller hole through the faced of the bezel to direct the light. Also to avoid straight on almost ponter light the LED would give off Thought I could scuff them slightly with fine sand paper...
The problem I found mounting them this way is that theres so much crap in that little bezel to try and work around...
What do you think??
Before I get happy with a drill I wanted to get some opnions.
Old Aug 4, 2009 | 08:52 PM
sampson01's Avatar
i have been debating this too !!!! kinda like a soft light pointing toward the center console !!
just bore a hole small enough to snug a 3 or 5mm led and hardwire it or to a switch
might have to anchor the led in with a lil dab of super glue but itll work
bout to make something happen this week... maybe thurs or fri
also thinking of mirror lights like of the new 350s on the tips for the mirrors .. like 3 amber running lights if you know waht i mean
Old Aug 5, 2009 | 08:32 AM
Big Slick's Avatar
what is this "moon lighting" you speak of?
Old Aug 5, 2009 | 09:02 AM
yetti96's Avatar
Yeah, not all of us are pretty boys and have been in a BMW before. Well I take that back, I tried to sit in a 325 once but really wanted to drive it because the owner offered. Well I might have been able to squeeze in but my foot covered the entire gas peddle and some of the brake. There was no way I could ever drive it safely or enjoyable. That was my last experience with a BMW. So mood lighting? Is it like the ambient lighting in the newer Fords?
Old Aug 6, 2009 | 12:38 PM
Yes it's like that...
Old Aug 6, 2009 | 12:39 PM
Let us know how that turns out! I'm hopping to give it a crack this weekend maybe!!
Your mirrior LED's pointing forward or down towards the running boards?
Old Aug 6, 2009 | 01:18 PM
cstanek's Avatar
My MDX has two blue LEDs near the map lights, right in front of the sunroof and a couple more near the floor on each side of the center console, so I've definitely thought about it before too. I bet you could pretty easily wire them into the dash lights since you'd want the LEDs to turn on with them. I've thought about somehow mounting them inside the lens for the map lights so you don't see them when they're turned off. I'm not sure how that would affect the light disbursement, though. That might save you from drilling holes, though.
Old Aug 6, 2009 | 02:12 PM
I thought about doing it that way also. But the problem I thought would be just that. The light would reflect inside the lens housing rather then being directed downward towards the console...
Old Aug 6, 2009 | 06:03 PM
sampson01's Avatar
well just finished the mirror leds.. 4 5mm amber in the mirror facing outwards tied in with the blinkers they are in the crevice on the mirror looks good will get pics later bt sunday is an other day off so that might be time for some leds in the foot wells and above in the maplight console pointing downwards
also waiting on my purchase of 6 3 led flashers kinda like tir3s that whelen has. to mount 4 in the rear window and 2 upfront next to my hellas
3 amber and 3 white .... gotta be bright to be seen right ??
Old Aug 10, 2009 | 11:06 AM
Get those Pics??
"gotta be bright to be seen right" RIGHT
Old Aug 10, 2009 | 01:44 PM
cstanek's Avatar
Originally Posted by Mr. eXtreme
Get those Pics??
Yeah, man. Where are the pictures?
