NEED HELP with Grille Emblem!
Old Jul 23, 2009 | 12:55 PM
kyleb822's Avatar
Any pointers on how to remove the stock emblem from the front grille of a Lariat? I removed the two metal bolts that are attached to the back, but it seems like its not meant to come out. I dont want to break it taking it out. It's like latched in and I feel like I have to bend the plastic around to get it out? Has anyone done this before?
Old Jul 23, 2009 | 01:02 PM
05RedFX4's Avatar
Yep, thats how it comes out. I suggest you put some heat on the tabs to soften the plastic so you dont break them, then with a little effort, it should come out.
Old Jul 23, 2009 | 01:08 PM
kyleb822's Avatar
what do u suggest to use to heat them?
Old Jul 23, 2009 | 01:32 PM
05RedFX4's Avatar
Swipe your ol' ladys blow dryer and use the highest heat setting. All your trying to do is soften the plastic a little so the tabs don't break. Once you get a little heat into them, give it a whack from the backside on the pins and it should pop right off.
Old Jul 23, 2009 | 01:33 PM
kyleb822's Avatar
thanks man, i'll give it a try
Old Jul 23, 2009 | 02:05 PM
kyleb822's Avatar
the hair dryer worked like a charm...it popped right out once the tabs were softened! thanks again!
Old Jul 23, 2009 | 02:17 PM
vtelvr's Avatar
I fought with my emblem for about 20mins before I said screw it. I got some painters tape, and newspaper, lifted the emblem enough to get tape on the under side so it would have a crisp edge, and went to town with the paint for my grille insert. Best idea I have had yet! haha!
