How will this turn out? Opinions?
Old Jun 24, 2009 | 10:48 PM
snuphacracka213's Avatar
Alright so I have a 2004 Lariat screw 2wd and I want to get some extra ride height... As much as I'd love to get a 6" lift it just doesnt fit my budget and in my opinion is kinda silly to put on a 2wd truck. But anyways, I was thinking of getting it leveled. Would I be able to fit 33's without rubbing? Is there anything I can add onto the leveling kit to get more height? Also, what leveling kit/add ons do you guys recommend as well as wheels/tires?
If anyone has any pics of a leveled 2wd Id love to see them...trying to figure out what itll look like.
Thanks guys
Old Jun 24, 2009 | 11:09 PM
jdruzik's Avatar
Increasing Hight...
A 2" to 2 1/2" leveling kit will give you the room to install 33" tires without rubbing. If the wheels have the correct backspacing you can go to a larger size tire without rubbing. My truck has a 2" leveling kit, Amp Bitterroot Wheels with 4.5" BS, and 34" Toyo Open Country MTs and no rubbing. That's about a 4" increase in hight. Check it out...
I hope this helps...
Old Jun 24, 2009 | 11:15 PM
Thats a great lookin truck, I love the tire choice! Will the leveling kit on my 2wd be at the same height as a 4x4 with a leveling kit? Are there different shocks I can add for extra height?
Old Jun 25, 2009 | 01:57 AM
hoss66's Avatar
your truck with a leveling kit will still be smaller than 4x4 with a leveling kit. there isnt anything to add with the leveling kit, you can either do this or a lift.
Old Jun 25, 2009 | 08:27 AM
FRYCREW's Avatar
Here's my 2wd with a 2.5" Auto Spring spacer, 2" lowering shackles in the rear and 285/65-18 BFG A/T's. I put the shackle on because I like my trucks to sit a tad higher up front.
Fry
Old Jun 25, 2009 | 11:45 AM
bigal13184's Avatar
that silver truck looks retarded with a leveling kit and lowering shackles in the back. dont do like he did
Old Jun 25, 2009 | 01:24 PM
thanks for the advice and pics, guys...is there a small suspension lift that isnt very costly that I could throw on there?
Old Jun 25, 2009 | 02:15 PM
yetti96's Avatar
How much is costly? $65 for an AS leveling kit and another say $70 for an alignment and you are level....OR.... $1500 minimum I think for a 4" or 6" lift kit plus the need for bigger tires and possible wheels.
Old Jun 25, 2009 | 03:39 PM
I just cant justify spending the money for a 6" lift along with new tires and wheels
Old Jun 25, 2009 | 06:15 PM
FRYCREW's Avatar
There you go, the expert has spoken. Don't be retarded like me.......
Fry
Old Jun 25, 2009 | 06:52 PM
RoushF150's Avatar
Aren't 2wd trucks supposed to be lowered?
But seriously, the 2wd's are fairly level anyway. I'd leave it alone.
Old Jun 25, 2009 | 07:18 PM
Fry
I think it looks fine...everyones got there own taste I guess.
Old Jun 25, 2009 | 08:03 PM
aPINCHbetter90's Avatar
I would say just go with a 2.5" leveling kit and either a 3" block to replace your 1-5/8" stock block or an add a leaf to get that back up. Cheapest option in my opinion and can be installed with just a couple of hand tools nothing crazy and they look great.
Old Jun 26, 2009 | 01:09 AM
hoss66's Avatar
his truck is a 2wd it has no rear block. if you wanted more lift in the back you could get a set of the factory 4x4 blocks.
