Help.. FAST!!!
Old Jun 8, 2009 | 06:46 PM
jalichoacan's Avatar
Exclamation Help.. FAST!!!
well i recieved my toyos ats today, but when i checked the tires, they said as i ordered, 325-65-18.. but then it said 35-13.00-18
are they gunna fit? its a 4x4 with a 2.5 as up front.. theyre at the shop right now and i need to know if theyre gunna fitt before they put them on... any help appreciated, please!!
Old Jun 8, 2009 | 07:00 PM
bjp207's Avatar
325's are way too wide for stock wheels, I highly doubt they wont rub, not to mention they are going to wear very funny
Old Jun 8, 2009 | 07:01 PM
ive seen people on here getting em on stock wheels, and i know theyll rub at full lock, my only concern is if the 13.00 will fit the well??
Old Jun 8, 2009 | 07:07 PM
anyone?? 13.00 to high, or will i be ok? i dont mind rubbing a bit..
Old Jun 8, 2009 | 08:02 PM
NoLongerJeepin's Avatar
Will the shop even install the tires? Most shops wont install a tire that wide on stock wheels due to liability issues
Old Jun 8, 2009 | 08:04 PM
im at the shop, the only thing is its too close to the uca
Old Jun 8, 2009 | 08:43 PM
well they fit everywhere except it rubs on the uca, so theyre getting a spacer in and they said that would fix the problem.. hopefully it works now, i got a migraine from thinking about it
Old Jun 8, 2009 | 10:29 PM
anyone?
Old Jun 8, 2009 | 10:35 PM
Anyone what? You said they solved the rub issue with a spacer in a previous post.
I think you need a wider wheel.
You should ask Wandell. He knows these things.
Old Jun 8, 2009 | 11:09 PM
what im asking is if a spacer is recommended, i know i need a wider wheel, but i also need money lol
im just wondering why a 325/65 is a 35/13 instead of a 12.5 like ive seen, and if its gunna fit without major issues
Old Jun 8, 2009 | 11:19 PM
08FX4's Avatar
A 325 series tire is technically a 12.79" wide tire but if I remember correctly most manufacturers spec the tire width closer to 13". IMO that tire is too wide for a stock 18" rim. You will probably have some uneven tread wear for sure.
Old Jun 8, 2009 | 11:21 PM
but isnt everyone running 325 on stock rims? how bout the 13.00 height?
Old Jun 8, 2009 | 11:31 PM
08FX4's Avatar
There are some people running 325 series tires on stock rims but it's not really the best thing to do. Not saying that it won't work because obviously it will but you run a higher risk of "popping" the bead off the rim in a high-speed tight turn situation and you are also pretty much guaranteed uneven tread wear which is crappy considering the cost of tires these days.
As far as the 13.00 height you keep asking about..... I'm a little confused. The 13.00 stamped on the side of the tire has absolutely nothing to do with the height of the tire -- only the width. If you're running a 325/65/18 that's simply a 35x13x18 tire which typically is a bit shorter but a bit wider than a 35x12.50x18.
Old Jun 8, 2009 | 11:39 PM
thats what i taught, the guy at the tire shop told me it was the height, and i told him if he could get a 35/12.5/18 and he said that would be 35/60/18
Old Jun 8, 2009 | 11:40 PM
Like said, the 13 is width, not height.
