power sliding rear window
Old Jun 2, 2009 | 12:14 PM
pdabbs911's Avatar
My power sliding rear window is not working. It was working last week no problem. I would appreciate any help trouble shooting this thanks! I have an 05 Lariat 4x4.
Old Jun 2, 2009 | 12:15 PM
abercrfootball's Avatar
It sounds weird but hit your button to open with a good amount of force... My driver side window and rear slider window buttons are going bad and i have to give them a good tap to open and close them
Old Jun 2, 2009 | 12:19 PM
johnnyd2723's Avatar
Check the TSB's. As I recall they had problems with the motors just being a bad design or placement issue. Also do a search here. This use to be brought up on a regular basis.
Good Luck
Old Jun 2, 2009 | 12:29 PM
pdabbs911's Avatar
Thanks for the help! Hey football: I tried the force thing and it did not work. I had another 05 that I had to fix the contact between the button before. It was really easy and worked fine. I basically just bent the thing a littlt to make a better contact.
Johnny: where would I check for TSB (I guess that is some type of bulletin)?
Old Jun 2, 2009 | 12:39 PM
TSB Technical Service Bulletin Look at the very top of the page, there's a tab to click on that say's "Recalls & TSB's"
Old Jun 2, 2009 | 02:03 PM
yetti96's Avatar
Power Sliding rear window not working is very common. My grandmother's '06 had this issue and basically the problem is not enough use to keep the cable lubed.
Old Jun 2, 2009 | 08:41 PM
pdabbs911's Avatar
At least it is closed
Old Jun 2, 2009 | 08:50 PM
pdabbs911's Avatar
johnnyd - thanks for the tip on the TSB. I don't think I have looked at that tab 2 times since becoming a member on this site. Thanks for the help!
Anybody -What is the concensus on the fix for the window??? Lube it, leave it, forget about it??
Old Jun 2, 2009 | 11:09 PM
Drunkonjack's Avatar
Boy isn't that something........I read this earlier and checked my rear slider and it won't open either.
Is there a recall for this thing
Old Jun 3, 2009 | 10:12 AM
pdabbs911's Avatar
I looked at the TSB's and did not see anything in there about the window. I could have missed it? I would like to get this thing fixed.
