Need a pic from ext cab guys
Odd request but I need a pic of where the seat belts bolt in underneath the rear seat on extended cabs. I've had my rear seat out for over a year and my dumbass forgot where they bolt in. Can anybody hook me up?
Thanks in advance
Thanks in advance
The mounting holes for the amps were perfect to stratle the indent running across the back wall. That allowed me to route all the speaker wires and rca cables behind them and out to the sides. Used stick-on zip tie clamps to hold the wires to the back wall.
The screws that come go through the back wall do they stick out side the cab??
I have been wanting to mount my amp here but just scared to make holes through the cab.
The raised portion that runs across is where I mounted mine to. The screws do not go all the way out the back. If you look to the right you can see part of the module for the keyless entry. It is factory mounted on that rail and there is also a ground point for the module on the same rail. So go ahead.
MOUNT EM!!
MOUNT EM!!
